Reuse Motordyne plenum spacer gasket?
Old May 18, 2024 | 11:26 AM
4drctr420's Avatar
4drctr420
Default Reuse Motordyne plenum spacer gasket?
I've had my 5/16 Motordyne thermal plenum spacer kit on for about 5 years now and the lower manifold aramid gasket has developed a leak near the engine bay.
I plan on replacing it with an OEM gasket but my question is will I need a new gasket for the plenum spacer? I feel like original gasket material Motordyne puts on the spacer will probably be worn out.
Will I have to clean off the spacer and install a OEM gasket on the bottom and possibly a z1 plenum spacer gasket on top?
Vq35de
Old May 18, 2024 | 11:29 AM
4drctr420's Avatar
4drctr420
Will these work or will the stock plenum spacer gasket be reusable?
Old May 18, 2024 | 12:23 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Zero experience with plenum spacer but plenty of experience with gaskets of every sort.
Rule of thumb: If you are going through the trouble of tearing something down that has a gasket, just replace it. Why not, to save money? You're gonna tear it down again to fix a leaking, used gasket. What's your time worth?
Never had a leaking gasket issue following this advice for the last five decades.
Old May 18, 2024 | 01:06 PM
4drctr420's Avatar
4drctr420
Thanks for the input, I usually have the same opinion but my main concern is that the Motordyne spacer comes with gasket material glued to the spacer.
​​​​​​I'll probably just but them all to be safe
Old May 19, 2024 | 09:39 PM
DarkZ03's Avatar
DarkZ03
This is one thing I will disagree with, if it's not leaking, leave it alone. It's basically the same aramid gasket bonded to the spacer (so you only have half the potential leaks).
I'm the second owner of the spacer and it's over 10 years old, I wouldn't hesitate to put it back on my car.
This it THE only style spacer I use and recommend using.
Old May 20, 2024 | 06:21 AM
4drctr420's Avatar
4drctr420
Thank you, that's good news. Im hoping the spacer will cling to the upper part of the plenum and hopefully not get damaged, but I bought a spare gasket just in case
jaminkid
Mar 8, 2006 06:05 AM
BootieMAN
Jan 29, 2006 04:53 PM
ZlleH
Dec 28, 2005 10:22 AM
stereoneeds
Dec 13, 2005 12:27 PM
corsair
Northern California
16
Oct 7, 2005 08:39 AM
