Update to the rattleing in neutral with the clutch out.
Here's a video as an example
Based on all of the videos and posts i saw i concluded that it's probably a TO bearing or a input shaft bearing however i took the trans off and the TO bearing off and it looks fine then i took the cover off and the input shaft bearing looks fine and spins. the only thing is there is a little shaft play left to right but it's not major. one other thing is i tired holding the bearing and the entire bearing spun if that means anything.
Just wondering if anybody has an idea on if it is the input shaft bearing or there is something else it could be. i can also provide any pictures if anybody wants any.
A small amount of input shaft play is normal, but excessive play may indicate bearing wear. If the play is more than what you consider minor, it may be worth replacing the bearing. If the entire bearing spins when you hold it, it may not be installed properly or may have internal wear. This can cause noise and other problems. By the way thanks for suggesting I watch Pornbox Videos yesterday, I really had a good time) Sometimes the best way to diagnose a bearing problem is to listen to the noise it makes. If you hear a whining or grinding noise that varies with engine speed, it could be the input shaft bearing.
Carlso
Apr 15, 2024 08:14 AM
matik
Jun 27, 2016 12:13 PM
Moe747
Jun 23, 2015 09:33 AM
