Large Rattling while in neutral with the clutch out only
Old Apr 12, 2024 | 03:05 PM
Carlso's Avatar
Carlso
Question Large Rattling while in neutral with the clutch out only
Whenever i have the car in neutral and the clutch out there is a rattling coming from the transmission. I think it is the input shaft bearing but i could be wrong. Does anyone have an idea of how serious the problem is and how difficult or expensive it is to replace?
Here is a video of the sound
Old Apr 12, 2024 | 04:32 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Here is a video of the sound https://youtube.com/shorts/Soy7C9V0p4Y?feature=share
Definitely louder than the usual CD0xx and the notoriously noisy JK and EA trannies. Does it go away when you put even just a little pressure on the clutch? Dumb question.... when was last time gear oul was swapped?
Old Apr 12, 2024 | 04:49 PM
Carlso's Avatar
Carlso
The more you push the clutch in the quieter it gets until it is fully in then it is silent. I have no history on when it was swapped as i bought the car with this problem
Old Apr 13, 2024 | 09:48 AM
icer5160's Avatar
icer5160
Much louder than normal. Most likely input shaft bearing on trans. But throwout bearing could be part of it. But since it gets quiet under load, I’m thinking trans. Either way, trans needs to come out to fix.
-Icer
Old Apr 15, 2024 | 08:14 AM
iideadeyeii's Avatar
iideadeyeii
TO bearing. don't worry about it.
skullface45
Jun 25, 2016 04:13 PM
DreamZcometrue
Jun 2, 2016 08:04 AM
MiRhodes
May 14, 2014 07:00 AM
oiyitsc4ry
Nov 24, 2013 05:01 PM
Igalaviz17
Sep 30, 2013 10:11 AM
