Crank no start 2005 350z Manual 168k miles
I just recently picked up a 2005 manual 350 that is a crank no start. Previous owner had changed all 4 cam sensors, crank sensor, and spark plugs and still nothing different. The only code it throws is a P0113 so I replaced the MAF and still no change.I was told they possibly thought it might be an ecu issue as it seems to spark at first then fall on its face. You can hear the fuel pump kick on and also smell fuel after cranking it. Any possible tips or recommendations that it could be? I can also send a video of me cranking the car if that helps. Thanks in advance!
Welcome and I'd suggest you test two items. First is how much fuel pressure you're getting at the fuel rail. Check the FSM for testing procedures. Also, is it possible the onboard NATS security system is causing the no-start?
checked for NATS and the red light is not on while the key is turned to the On position. Will test fuel pressure this weekend
itzlen
May 8, 2016 05:32 PM
