UR Crank Pulley = Squeal at Start-up??
Old Mar 16, 2004 | 08:09 AM
Phatmitzu's Avatar
Phatmitzu
Question UR Crank Pulley = Squeal at Start-up??
Installed my UR Under Drive Crank Pulley last week. NOw ever so often when I start-up my car, it makes this loud squeal noise. Screeeeech! It will only last couple of seconds tho, and it only happens at start-up, idle and driving are perfectly fine. But its pretty annoying. Is this normal? Or is there anyway to eliminate it?
Thanks!
Old Mar 16, 2004 | 08:15 AM
FLY BY Z's Avatar
FLY BY Z
tighten your belts.
Old Mar 16, 2004 | 08:18 AM
westpak's Avatar
westpak
SFZCC
Originally posted by FLY BY Z
tighten your belts.
Dito, mine does not squeal
Old Mar 16, 2004 | 08:47 AM
all_bark's Avatar
all_bark
or get the corrected sized belt. one of the listed belts is just a little to large so I had to take it off, bring it in and get one 1/2 inch smaller.
NO SQUEAL!!!!!
Old Mar 16, 2004 | 08:58 AM
al503's Avatar
al503
I put mine in last Sunday. It was fine Sunday and yesterday but I heard the squeel this morning for about a second or so.
I checked the tension on the belts with the stock pulley on and I thought that I tightened the new belts even tighter. If it keeps happening, I'll try to tighten them even more.
Is there a point where someone could overtighten the belts?
Old Mar 16, 2004 | 11:43 AM
scubasteve's Avatar
scubasteve
What the others said is correct. 1) change the belt size, I believe it is to be 44.5 inches, not 45.5. 2) tighten a bit more. I forget the amount of slack to leave, but at least check your belt before you remove it, then make it a bit tighter when you replace it with the shorter belt. I have had no squeaks or anything like that sinced installing mine. I had to go across town to get the right belt size in the Goodyear Gatorback brand, but it is well worth the extra 10 or so dollars for a better belt. Good luck!!
Old Mar 16, 2004 | 11:51 AM
westpak's Avatar
westpak
SFZCC
I got mine from Concept Z and it came as a kit with the pulley and 2 belts, worked great.
Old Mar 16, 2004 | 12:04 PM
ares's Avatar
ares
Veteran
you notice it squeels when its humid or raining?
belts stretch with use, so everything might be the right size, and tightened properly at the beginning, but still need to be retightened.
Old Mar 16, 2004 | 12:42 PM
EL Diablo's Avatar
EL Diablo
No squeel here. had the Pulley over a month.
Old Mar 17, 2004 | 04:23 AM
j's350z's Avatar
j's350z
A 44" belt is your best bet. The 45 1/4" that UR recommends is too big. We have installed half adozen of these alreay and with the belt they say to use, the tensioner has to be brought to the end of adjustment, and then it is still usually still loose... The main Crank/Alternator belt size that I found works well is the 6040...
Jason
Old Mar 17, 2004 | 07:52 AM
DrVolkl's Avatar
DrVolkl
I had the same problem with my 02 Maxima when I put the UR pulley on. The belts need to be tightened correctly, and during the install I busted one of the belt tensioners. Long story short, it cost a $90 trip to the dealer to fix it...but it never squaked again.
Old Mar 17, 2004 | 09:30 AM
Phatmitzu's Avatar
Phatmitzu
alright. Thanks for the replies...I will try tighten the belts more this friday to see if that will fix the problem.
Old Mar 17, 2004 | 09:32 AM
BJF2K's Avatar
BJF2K
either the belt too tight or too loose... so try it out
Old Mar 18, 2004 | 05:06 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
I have had it on my car for awhile and enarly 10k miles- no squeals at all, using the belt size UR has listed in their instructions
Old Mar 18, 2004 | 03:34 PM
scubasteve's Avatar
scubasteve
That is odd......I have read other people with the same comments. I guess there is some variance with vehicles......I wonder if there is any correlation with models or build dates???? I thought all VQ35 motors were the same, but some people have to use the shorter belt while others are fine with the longer (recommended) belt size by UR. When installing mine, I thought it was because I did not install the alternator pulley, but then common sense kicked me in the ***, remembering that they sell the pullies individually. I guess as long as you can properly tension the belt while allowing room for future adjustment, all will be ok. It is interesting, however, the issue with varying belt sizes that people use.
Old Mar 18, 2004 | 08:31 PM
isalvus's Avatar
isalvus
i should be getting mine soon, i ordered them with the belts hopefully their the right size. any way i need to know what size is the nut holding the crank pully, so i can get all the supplies i need to do the install i think it might be a 19 mm but not sure.
anyone know?
Old Mar 19, 2004 | 04:22 AM
j's350z's Avatar
j's350z
Yup, its a 19mm to remove the pulley and you are going to need a LONG 1/2" breaker bar to due so. And youned a 14mm open end to loosen the tensioner pulley and a 12mm socket to move the adjustor rod...... Heres a tip, put the car in gear and have someone stand on the brakes when you try to break loose the crank pulley, Also do this when re-installing.... And I reccomennd a 44" belt for the crank/alternator.... Just my opinion but it works!
Jason
www.racemrc.com
jason@racemrc.com
Old Mar 19, 2004 | 08:09 AM
ChrisMCagle's Avatar
ChrisMCagle
Default U/R Recommended belts
I too used the belts sizes that were recommended by U/R and have had no problems. There was a squeal the next day after the install, but after tightening the belts, it's gone and has not returned. I was wondering too about how tight they should be though? Mine are really tight. I was actually afraid that they might snap, but so far so good.
-Chris
Old Mar 20, 2004 | 07:21 PM
Coz@CZP's Avatar
Coz@CZP
Concept Z Performance
We actually offer Nissan Belts with the UR pulleys kits, and we replaced the 45 cm belt with a 44.09 cm belt, and haven't had a problem with them since
Coz
Old Mar 21, 2004 | 12:15 AM
Phatmitzu's Avatar
Phatmitzu
tighten the belt yesterday... problem fixed. no more noise.
