guaging intrest in B&M short shifter
Old Apr 16, 2004 | 06:50 AM
  #81
3rdpower's Avatar
3rdpower
I wonder if I got this last one? I placed an order and got a reciept last night.
Jessie_lee3 is my Ebay. PM the tracking # to me when you get the chance.
Old Apr 16, 2004 | 11:19 AM
  #82
3rdpower's Avatar
3rdpower
Tracking number recieved... on the way
Old Apr 16, 2004 | 01:23 PM
  #83
gra350z's Avatar
gra350z
Fedex just delivered mine today. Thanks again Justin.
Gary
Old Apr 16, 2004 | 08:26 PM
  #84
mucky's Avatar
mucky
I recieved mine earlier today(friday) and got it installed. Shifts good. One thing I notice is when the rpm's go above 4k the shifter makes a wierd noise. I also noticed it on the freeway. I think it may be the rev. pin tapping the plate when in 5th & 6th gear. Anyone else have this problen. If so how do I fix it?
Old Apr 16, 2004 | 08:41 PM
  #85
bigern1970's Avatar
bigern1970
Go to www.zchickz.com see their short shifter setup on the reverse pin.......its not a b&g but its the same theory or reinstalling. might work it had a part about making sure 5th and 6th gears had clearance .........tell me what happens,,,, I want a b&g
Old Apr 16, 2004 | 09:05 PM
  #86
ssk0771's Avatar
ssk0771
I think wld350z has that problem too but I thought they fixed it?
wld350z has a prototype.
Old Apr 17, 2004 | 01:44 AM
  #87
fairladyZ in Japan's Avatar
fairladyZ in Japan
I sent a PM to wld350Z... hopefully he will post regarding his experience.
Old Apr 17, 2004 | 03:52 AM
  #88
wld350z's Avatar
wld350z
Default just my 2 cents
i have the 1st production shifter in my car the only noise i get from it is when you push it hard into the gate example( when you power shift say into 3rd gear had hold it frimly against the stop and dont relax your hand other wise i have 0 noise or vibration comming from it) the noise or vibration from the shifter is transmited from the transmission and when you hold it frimly against the stop you can fell it slighty. the cause is from using Orings to connect the 2 pieces of the shifter together.
you get a much more postive fell with Orings instead of a big hunk of rubber between the lower and upper shaft .
but as far as i fell it is a great shifter. and it will not come apart no matter how hard you push or pull
i hope this helps some people out there
Old Apr 17, 2004 | 03:57 AM
  #89
wld350z's Avatar
wld350z
Mucky iam sure if you are having problems you can call B&M they are very nice people there or send me a pm if you wish my help but every body that drove the car said they HAD to have one
and just loved it execpt ssk0771 he said it had a small vibration but then again !
Old Apr 17, 2004 | 05:19 AM
  #90
fairladyZ in Japan
Default thanks !!!!
Tony.. thanks so much for posting. This is going to help a lot of people including myself.. A couple of questions..
1/ Just to confirm...
a/ A blue mounting plate comes with the new short shifter...
b/ The original stock plate will then be placed over the blue plate and screwed on with the new M6 bolts ... correct ? At least that is what I understand from the instructions.... step 15
2/ You have to file a little on the shifter casing ..
The 0.125" filing points on the upper left hand side ... question...
From the upper left 90 degree angle.. how many inches to the right and -- how many inches down should this be filing be done ?
thanks...
Old Apr 17, 2004 | 01:03 PM
  #91
ssk0771's Avatar
ssk0771
Hey Whats UP Tony,
I never said I did not like the shifter. I actully love it. You were there when I drove your car. I just did not like the vibration noise on the shifter.
Are you at the MEET? Today.
Old Apr 17, 2004 | 01:50 PM
  #92
mucky's Avatar
mucky
I think the rattle is coming from the shift ****. What would the reason be for this?
Old Apr 17, 2004 | 06:33 PM
  #93
Melissa's Avatar
Melissa
i absolutly love mine
no noise no rattle...and the shift is remarkable
Old Apr 17, 2004 | 07:10 PM
  #94
mucky's Avatar
mucky
Maybe not. I can't figure it out and it's kinda driving me crazy. I like the way iot shifts, but for $200, I'm not sure the noise is worth it.
Old Apr 17, 2004 | 08:44 PM
  #95
dholly1's Avatar
dholly1
Wasn't there a RE shifter install thread where someone had a buzzy ****? Maybe the camfered spacer vibrating? IIRC, he simply removed **** and re-tightened, no more buzz.
Old Apr 19, 2004 | 10:25 PM
  #96
KJY9's Avatar
KJY9
thanks Justin...got mine today!
Old Apr 19, 2004 | 10:40 PM
  #97
wakaZ's Avatar
wakaZ
Dang...all you lucky guys...
Still waiting on mine...I guess living in the middle of the Pacific Ocean does kinda suck a little
Old Apr 19, 2004 | 11:11 PM
  #98
AmyCroft's Avatar
AmyCroft
But so many pretty Girls..
Cheers Amy -
Old Apr 19, 2004 | 11:38 PM
  #99
wakaZ's Avatar
wakaZ
Cheers Amy -
Everywhere...
Old Apr 20, 2004 | 09:53 AM
  #100
Phatmitzu's Avatar
Phatmitzu
How about a group buy?
https://my350z.com/forum/showthread....threadid=71213
GOGOGO!
