View Poll Results: Interested in an engine oil cooler kit?
Very interested (would purchase)
20
48.78%
Somewhat interested (might purchase)
19
46.34%
Not interested
4.88%
Voters: 41. You may not vote on this poll
Interested in an Engine Oil Cooler Kit?
Old May 9, 2004 | 03:07 PM
Mr B's Avatar
Mr B
I am interested in a high quality kit like you speak of. At $500, it's a steal compared to other companies like Greddy's, ARC's and Nismo's. Lemme know if you need any help azrael.
Old May 9, 2004 | 03:26 PM
ether's Avatar
ether
would the system inlude a tap for an oil te mp sensor or would adding a spacer/tap to the remote filter mount be a solution
Old May 9, 2004 | 08:16 PM
azrael's Avatar
azrael
this kit would not include an adapter for the temp sensor, but I do have some sensor mounting hardware in the works.
if you wish, you could use an adapter tee in line with the hoses to add a temperature sensor, although the oil cooler lines are -10 AN in size, so any adapter tee would have to have another fitting to change to 3/8 NPT, which is the standard thread size for sensors.
The stock oil pressure switch attaches to the block with a 3/8 BSPT fitting, which is where people usually add temp and pressure sensors. The problem is that 3/8 BSPT isn't quite compatible with 3/8 NPT. Like I said, I have a solution in the works.
Old Aug 18, 2004 | 06:49 AM
arizzee's Avatar
arizzee
Any updates on this project? Still need an oil cooler.
Old Aug 18, 2004 | 02:08 PM
hungster's Avatar
hungster
just go and get those products and connect them yourself, thats all he is doing but putting it together and market up the value.
liqalu04
Jan 2, 2022 12:58 PM
Dsowe
Feb 17, 2021 10:38 AM
kyin
Oct 15, 2015 05:54 AM
