How do I get the crank pulley off??
Old Apr 5, 2004 | 03:01 PM
al503's Avatar
al503
Originally posted by jng1226
Thank you for the first-hand information. I really like the guys at my local shop, so that is disappointing if they are trying to milk me. He told me they probably would have to take off the radiator to do it correctly, and subsequently drain it and re-fill it. I am afraid of the responses that is going to get...
I was only talking about the crank pulley. If you are talking about all 3 pulleys, it will definitely take a little longer. I think you have to take the alternator out to install that pulley but you definitely don't have to remove the radiator.
Old Apr 5, 2004 | 03:07 PM
roark's Avatar
roark
2-3 hours is what it takes to do the 3 pulley kit. If your shop has never done this job before is just padding the job to make sure they don't loose their ***. Talk to them and ask why the high labor estimate. If they are reputable, they should give you a reasonable estimate and only charge you for the time it actually takes.
Good luck.....
Old Apr 5, 2004 | 03:14 PM
jng1226's Avatar
jng1226
Thanks guys. I am indeed only interested in the crank pulley. I did say that to the service guy, but perhaps he automatically assumed I meant all three.
Old Apr 12, 2004 | 04:07 AM
westpak's Avatar
westpak
SFZCC
No, I asked and was also told 2-3 hours and removal of the radiator because they have to be able to get the air gun in there, they don't know how to work without them.
Old Apr 13, 2004 | 09:22 AM
C5DEMON's Avatar
C5DEMON
I did the job last night with an 18" breaker bar! It took some serious grunts, but the bolt gave in. It took me two hours total, only because I finished in the dark at 8:30pm, and had to feel my way around the bottom of the car to reinstall the plastic cover.
Easy DIYer. By the way, no gloves and NO CUTS! First project I have ever done with out shredding up my hands.
Love the mod!
Old Apr 13, 2004 | 10:39 AM
ronald_m's Avatar
ronald_m
Love the mod!
Did somebody help you out?I mean did somebody mashed the brake pedal for you?How do you remove the crank bolt,counter clockwise?
Old Apr 13, 2004 | 12:26 PM
C5DEMON's Avatar
C5DEMON
My fiancee stepped on the brake. I yanked on that biatch... the bolt, not the fiancee, with every ounce of strength in my body to get it to move. And yes, it is counter clockwise.
Old Apr 13, 2004 | 05:55 PM
CaneZMD's Avatar
CaneZMD
Yeah, It's pretty tough.
I did it alone. I put the car in 6th and jacked up the parking brake as hard as I could.
I ended up using a 3ft steel fence post that I bought from Home depot. It worked great.
Old Apr 14, 2004 | 04:18 AM
westpak's Avatar
westpak
SFZCC
Way to go doc, hope all worked out well with your plenum situation, any hopes of seeing you at Zfest this weekend?
Old Apr 14, 2004 | 07:20 AM
flynnibus's Avatar
flynnibus
Z Flier
sorry guys... this thread is too funny to read on all the 'tools' you guys have resorted to using
Old Apr 14, 2004 | 10:43 AM
infidsg35's Avatar
infidsg35
Ha Ha fence post, conduit, and the BEST a Hockey Stick LOL..
Im going to be doing this mod now I need to think of something else to add to the list LOL
Old Apr 15, 2004 | 11:58 PM
MySunset350Z's Avatar
MySunset350Z
i also used the "blip" method with an 18' breaker bar. nothing to it.
i think i overtightened the belts though. how did you guys know when to stop tightening?
Old Apr 16, 2004 | 03:14 AM
westpak's Avatar
westpak
SFZCC
I just did it by feel, I would tighten until there was a slight deflection on the belts and no noises from slipping.
Old Apr 16, 2004 | 07:54 AM
C5DEMON's Avatar
C5DEMON
Mine are so tight that there is no flex at all. But, there is also no squeeling! My tensioners could still go tighter too and I am using the belt UR recommends.
Old May 28, 2004 | 08:26 PM
menace_z's Avatar
menace_z
Alberto
thank for the technique i did it and work fine and now i need to bolt back on the screw so can any idea and help????
Old May 28, 2004 | 08:30 PM
menace_z's Avatar
menace_z
i have an auto and every time i try to tight tbe crank pulley keep moving help me out with some technique
Fixxxercask
Nov 9, 2015 11:10 AM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
