Rough idle...
Old Apr 6, 2004 | 11:44 AM
CTZ's Avatar
CTZ
Default Rough idle...
I posted at another site, but was hoping to get more feedback here.
I had a polished plenum installed about a month ago. Professional install and the plenum was brand new. I have driven the car about 4 times since then (CT driver here) and have noticed that my idle is rough. It stays at 750rpm for a bit then dips down. When I get out of the car and listen... it sounds like it is sputtering a bit. Car shakes alittle.
I don't feel any loss of power at all while driving it. Appears to be only when stationary. 5500 miles on the car... babied. No performance mods!
I made an appt. at the dealer for this Friday. I am nervous!
Whataya guys think?
Vacuum line?
Bad Spark plug?
Bad fill up of gas!
Old Apr 6, 2004 | 07:58 PM
Shocka's Avatar
Shocka
Bad gas could cause the problem, as could a vacuum leak.
I have a similar problem with rough idle then dropping off and misfire. It is showing up as a lean condition on the right side O2 sensor. As to the cause......that is still to be determined.
Old Apr 7, 2004 | 10:16 AM
CTZ's Avatar
CTZ
Thanks Shocka... appreciate the feedback. I am surprised... I got more responses from zcar.com. Ha!
We'll see what the dealer says.
Old Apr 8, 2004 | 09:20 PM
F2dmfine's Avatar
F2dmfine
Please keep me posted on this, I am having the same exact problem, and I have the following mods on my Z: Crawford Plenum, Japtrix Y-Pipe & Mid-Pipe, UR Crank Pulley, drop-in K&N.
I am also concerned as to what could be causing this, one Forum member who was having the same problem told me that it was his MAF sensor. I was also wondering if maybe a fouled spark plug could be causing it. Any feedback on this matter would be greatly appreciated.
Old Apr 8, 2004 | 10:20 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
The Z is notrious for a rough idle...even in stock configuration. A lot of folks installed grounding kits, and it immediately smoothed out the idle.
Old Apr 9, 2004 | 10:22 AM
CTZ's Avatar
CTZ
My idle was more than rough and it didn't sound very good...even from the outside. Almost like it wanted to stall.
I got a call from the dealer today and they said that there was a leak in the intake gasket!! They did several computer tests.. etc.
My dealer isn't mod friendly (even cosmetically) and I did not get this installed with them. We'll see if the dealership that ordered/installed this for me can contact my delaership to get this taken care of. Otherwise...trip to NY is in the works.
Funny thing is... this confirms why I should leave the car the way it was from the damn factory and just enjoy driving it! So annoying.
Hope that helps guys.
hulkout
Apr 28, 2017 09:00 PM
ablaine
Nov 29, 2016 10:13 AM
SanmarinoZ
Oct 21, 2015 10:04 AM
bneumann
Oct 7, 2015 12:16 PM
Darkspy
Sep 7, 2015 09:09 PM
