Switching to synthetic oil
Old Apr 6, 2004 | 10:08 PM
Dunc's Avatar
Dunc
Default Switching to synthetic oil
Anyone care to give me an opinion on going with either Royal Purple or Mobil one synthetic oil and what weight for warm climate?
Search still not working
Thanks
Old Apr 6, 2004 | 11:42 PM
Selski12's Avatar
Selski12
Have not tried royal purple yet, but have done mobil 1 syn the past 2 oil changes. I always look forward to the day of new oil with Mobil 1 syn. I can definitely feel the car is way smoother and is evident especially when shifting/downshifting. The revs are just smoother.
Just some input on my experience with Mobil 1 synthetic.
Old Apr 6, 2004 | 11:52 PM
mushutofu's Avatar
mushutofu
Unless your really driving your car hard mobil one i think does the job just as well. One big factor is that it is way cheaper the royal purple.
Old Apr 7, 2004 | 06:39 AM
3rdpower's Avatar
3rdpower
Mobile 1 15/50 since day one. I love it... I can always fill the difference after an oil change. I love Royal Purple and especially RedLine, however, cost to get outweighs real need.
Old Apr 7, 2004 | 06:50 AM
JasZ's Avatar
JasZ
Redline or Royal Purple?
Old Apr 7, 2004 | 09:41 AM
3rdpower's Avatar
3rdpower
been discussed many times. RedLine is the best in my humble opinion.
Old Apr 7, 2004 | 12:30 PM
JasZ's Avatar
JasZ
Search is broken so I dare to ask why Redline considered better?
Old Apr 7, 2004 | 01:09 PM
VQ35DES's Avatar
VQ35DES
Redline, if not not Mobil 1. Royal Purple is hype, over priced...like fram.
Anyone know if frams still have cardboard endcaps? They did the research about two years ago, so it may have changed; like how bosch changed to cardboard when the switched the production over to mexico.
Old Apr 7, 2004 | 05:44 PM
Dunc's Avatar
Dunc
Looked up Redline and its about the same price as Royal Purple both are over 6 dollars a quart. What grade are Mobil one guys using? Another interesting thing ive found from drilling down on this is Redline seems to be more available locally than Royal Purple and mobile one is everywhere.
Red Line 15W50
The ultimate high-temperature protection in Red Line engine oils recommended for street use. Good for engines that regularly run very high oil temperatures. Best for engines that run large clearances such as air-cooled engines or large-displacement, all-out racing engines that see occasional street use. Provides 25% more viscosity in bearings than petroleum 20W-50s. Not recommended for use in cold climates where temperatures are at or below 10°F or -12°C. Not recommended for street use in production engines that see sustained oil temperatures below 225°F (those engines should use Red Line 10W-30 or 10W-40).
Old Apr 7, 2004 | 09:50 PM
350ed's Avatar
350ed
Professional
What's the best weight to use in non-freezing environments for our vq35?
Old Apr 7, 2004 | 09:53 PM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
Check your manual on that, it has a temp scale and recommended oil weights. I use Mobil one synthetic for engine oil and the rear differential
Old Apr 7, 2004 | 10:57 PM
MarkY's Avatar
MarkY
I don't pick up my wife's Z until this weekend. Does the Z come with synthetic from the factory? Also, when is the first "scheduled" oil change? I usually dump the original oil after about 500 - 1000 miles. I would probably switch to Mobil One after that.
Old Apr 7, 2004 | 11:08 PM
350ed's Avatar
350ed
Professional
Good point, but it's way over there in the garage in my glove compartment. Have some compassion!
Old Apr 7, 2004 | 11:27 PM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
Mine isn't in a garage at all, it's out getting jizzed on by all the trees
Old Apr 8, 2004 | 02:55 PM
350xfire's Avatar
350xfire
I use 5w30
Old Apr 8, 2004 | 08:41 PM
350ed's Avatar
350ed
Professional
I hear ya, mine gets it while I'm at work. I think some of my coworkers touch themselves when they see it too
Old Apr 8, 2004 | 10:07 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Isn't Royal Purple semi-synthetic? That's why I choose Mobil 1
Old Apr 9, 2004 | 08:46 AM
fluidz's Avatar
fluidz
Red Line is in my little beast!......
Old Apr 9, 2004 | 01:21 PM
Dunc's Avatar
Dunc
What grade ?
Old Apr 9, 2004 | 02:24 PM
fluidz's Avatar
fluidz
Originally posted by Dunc
What grade ?
10/40
