For those with Rouge Short Shifters
Old Apr 8, 2004 | 05:09 AM
aproy's Avatar
aproy
Default For those with Rouge Short Shifters
Those of you who broke them, or who just have them, do you hear a BAD vibration coming from the shifter, like where the silicone is?
when i get high in the rpms (5-6k) it buzzes real bad, i wonder if the silicone is wearing out, i got one of the first ones from Ben.
Old Apr 8, 2004 | 06:11 AM
ZIABLO's Avatar
ZIABLO
I am Batman
I have no buzzing, I've only had it in for 2 months though
Old Apr 8, 2004 | 06:13 AM
jesseenglish's Avatar
jesseenglish
No buzzing, I was one of the first to order mine.
Old Apr 8, 2004 | 05:01 PM
G3po's Avatar
G3po
Default Rougue shifter
Installed mine 2 months ago, I did notice a little chatter in 5th under high load /deload. I adjusted the "knub" away from the side gate a little and the noise disappeared (at the slight expense of a little notchiness going into 5th and 6th. The normal gear vibrations were causing the shifter to resonate against the guide plate. Also I think my Borla TD exaggerted this vibration a little over the stock exhaust.
Old Apr 8, 2004 | 05:35 PM
aproy's Avatar
aproy
oh ya, i didnt even think of that, maybe the gate came loose a little. thanks for the idea!
Old Apr 16, 2004 | 04:47 AM
aproy's Avatar
aproy
it is definately the shifter. i took the center console apart and there is about 2-3mm of play on the "joint" of the shifter.
Old Apr 16, 2004 | 05:26 AM
John's Avatar
John
I have the original design shifter, and have noticed no noise / vibration or any problems in 4+ months of use...
Old Apr 16, 2004 | 07:16 AM
DeeZee's Avatar
DeeZee
i have the version 2 shifter. i have had it for MONTHS (sinc Jan.) with no problem. its still my favorite mod so far. it seems to viberate at high rpms, but there isnt a sound coming from it. im also using the titanum nismo ****, so im sure i feel it mone than the stock ****. but i LOVE the shifter now!!! i dont even notice the vibration, unless im at a light at idle, and i look down at my hand on the shifter. you can see it moving alot, but i dont seem to feel it?????
Old May 23, 2004 | 04:38 AM
Z BOY's Avatar
Z BOY
How does the rogue compare to the b&m short shifter, which is about $80 less.
Old May 23, 2004 | 07:09 AM
Gsedan35's Avatar
Gsedan35
As far a noise or vibration mine is the same as oem, I have the latest version (V2 I guess). I have nothing to complain about.
Old May 23, 2004 | 07:50 AM
scz's Avatar
scz
What is the difference in throw vs. our stock short shifters?
Old May 23, 2004 | 02:23 PM
DeeZee's Avatar
DeeZee
RE is 20% reduction, and i "think" B&M is 33%? the B&M is a little less $$$, but i have been hearing mixed reviews. still no problems with my RE V2. if i had to do it again right now, id still get the RE. hope that helps. the extra 13% is tempting, but not with the problems i have been hearing about. do a search.
Old May 23, 2004 | 03:10 PM
jmark's Avatar
jmark
No probs. with my V2 RE shifter. Nice addition.
Old May 23, 2004 | 04:25 PM
ether's Avatar
ether
awesome mod.. no problems with a ver1 here
Old May 24, 2004 | 06:05 AM
Eagle1's Avatar
Eagle1
I have the RE V2, and no vibration or noise, installed in January.
Old May 24, 2004 | 09:15 AM
G3po's Avatar
G3po
Default rouge
Had mine for 6mo. Only issue is that mis-adjustment of the guide plate can either make 5@6th notchy (too much clearance) or rattley (too little clearance) . Took me 3 tries to get it just right.
Recommendation, after basic install/ adjust , replace the **** and drive the car in all gears and on the freeway , accel and decel before putting all the boots and plastic back on. LSight adjust may be needed. Given that , it works like a champ and is a vast improvement over OEM.
Old May 25, 2004 | 08:50 PM
scz's Avatar
scz
Default Re: rouge
where is the best place to buy one?
Old May 26, 2004 | 12:32 AM
DeeZee's Avatar
DeeZee
pm bj @ 350evo.
Old May 26, 2004 | 09:09 AM
G3po's Avatar
G3po
Default Rouge
Bought mine from BJ@350EVO, no complaints.
Old May 26, 2004 | 10:38 AM
aproy's Avatar
aproy
Default Re: Re: rouge
i got mine straight from Rouge, ask for Ben.
