Rwhp?
Old Apr 14, 2004 | 06:41 AM
Duflacci's Avatar
Duflacci
Default Rwhp?
I posted this on another forum, some of estimates were realistic and a few were very conservative.....
Wondering what my RWHP is with all the mods I've done....After friday 4/16/04 I will wonder no more ........ Headin' up to Balanced Performance ......anyone care to guess what It will be.....The closest guess wins .....NOTHING....
note...( look at sig for list of mods )
Old Apr 14, 2004 | 06:44 AM
PoWeRtRiP's Avatar
PoWeRtRiP
250, your nismo/aem intake is holding you back, pay attention to your a/f it will be around 13.9-14.2 at low rpms
Old Apr 14, 2004 | 06:45 AM
ares's Avatar
ares
Veteran
Ill say 260. but with no baseline its real hard to tell.
but whatever it is, I wonder if it turns out being worth 3000$.
bet it sounds nice though.
Old Apr 14, 2004 | 06:48 AM
ares's Avatar
ares
Veteran
everything nismo holds you back, its all relative though. it "should" all be better than stock, just not as good as other aftermarket brands. from a power standpoint.
Old Apr 14, 2004 | 07:01 AM
fluidz's Avatar
fluidz
Old Apr 14, 2004 | 07:02 AM
Duflacci's Avatar
Duflacci
What is the difference between the nismo/aem and some of the others.......would making the cai shorter help?
Old Apr 14, 2004 | 07:06 AM
PoWeRtRiP's Avatar
PoWeRtRiP
no the problem with them is where they are mounted. the results with them has not been as great as those with the jwt or the injen. it may even lose power on some cars, the best gains i have seen from the aem/nismo was 2-3 whp while the jwt and injen are usually around 5
Old Apr 14, 2004 | 07:10 AM
shef's Avatar
shef
Default Re: Rwhp?
263
Old Apr 14, 2004 | 07:21 AM
KrazY-2K's Avatar
KrazY-2K
265 at the most
Old Apr 14, 2004 | 07:48 AM
Rayden2001's Avatar
Rayden2001
Old Apr 16, 2004 | 08:19 PM
Duflacci's Avatar
Duflacci
255.4 rwhp
242.4 ft lbs
Old Apr 17, 2004 | 02:45 AM
little_rod's Avatar
little_rod
Well, $3K-$4K for probably 20+ rwhp, good setup, hardly seems worth it though.
Old Apr 17, 2004 | 03:21 AM
Duflacci's Avatar
Duflacci
I feel its kinda low.....my friend who works for nissan thought so too taking into account all the mods....he feels the equipment was not accurate and found another place to bring it to get dynoed next week.....
Old Apr 17, 2004 | 03:47 AM
little_rod's Avatar
little_rod
Not downing the setup at all, those numbers are typical for the setup I believe. From the numbers of others, yours seem to be inline
Old Apr 17, 2004 | 04:14 AM
Duflacci's Avatar
Duflacci
When all the mods are summed up I guess it seems close to expected......the real test is the butt dyno....... ... and the butt is content with the results.....
so whats next ati procharger or greddy TT?
Old Apr 17, 2004 | 05:38 AM
Duflacci's Avatar
Duflacci
heres the printout
Old Apr 17, 2004 | 05:40 AM
Duflacci's Avatar
Duflacci
Originally posted by Duflacci
heres the printout
Old Apr 17, 2004 | 07:08 AM
ares's Avatar
ares
Veteran
well with no baseline its real hard to tell. but Id say its most likely pretty accurate.
you probably will find another dyno that will give you a higher reading, but does this mean your really have any more HP? dynos are all relative, you can only truely compare one run to another run when all variables are the same, this includes the dyno location, and when you actually dyno.
some people say to run the car till the radiator fan kicks on, then when it kicks off, run it RIGHT then. but with no baseline, you have no idea. dynos should be looks at as 255hp, but instead as 15hp over stock which was 240.
Old Apr 17, 2004 | 09:27 AM
little_rod's Avatar
little_rod
Well, if you do a TT, you can forget those nice and expensive Crawford headers. From your mods, it appears the SC would be a good choice, you would just lose the Nismo intake. Course, those pullleys will probably have to go also.
