Dyno result!
Old Apr 19, 2004 | 10:44 AM
Z PHAT Z's Avatar
Z PHAT Z
Default Dyno result!
Well, after switched out the XERD headers and putting in Stillen shorties and Kinetix hi-flo cats, I re-dyno my car. A/F shows i'm running kinda rich.
Old Apr 19, 2004 | 11:35 AM
Alberto's Avatar
Alberto
Cranky FI Owner
What line is what? What was your best hp/tq before with the XERD's and what is it now with the Stillen/HF Cat set-up? Thanks....
Old Apr 19, 2004 | 11:37 AM
zparts's Avatar
zparts
Default Re: Dyno result!
Do you have any baseline info to compare to?
Old Apr 19, 2004 | 03:16 PM
Z PHAT Z's Avatar
Z PHAT Z
My base number was 227 WHP , 217 WTQ. With the XERD I got like 245 WHP, 231 WTQ. Those 3 lines are my 3 runs. As you can see, the HP graph is still going upward. If they ran until redline, I think I will get more. They stopped at 6550.
Old Apr 19, 2004 | 08:50 PM
jng1226's Avatar
jng1226
That's cool that you tested on a Dynapack dyno. I didn't know anything about them until I went and had my 2003 Track dyno'd (first car ever dyno'd). I think it's pretty cool how they hook your axles up directly to the dyno boxes for each wheel, it really seems much more accurate (especially for fine tuning) than a massive roller-style Dynojet that can be sensitive to wheel weight, pressure, etc. My local guy showed me how detailed the readings were by turning the A/C on and off and watching the real time HP readings, it seemed very sensitive.
Are these runs with the Dynapack software correction factors? I dynoed mine about a month ago and got 236.5 as a baseline (average of 3 runs and threw out a 244.5 hp 4th run as ECU optimizing during successive runs). With only my Topspeed Pro-1 exhaust I got an average baseline of 246 of 3 runs. With the silencers in place I only lost .8 hp on 2 different runs.
Old Apr 20, 2004 | 02:52 PM
DriftinZ's Avatar
DriftinZ
What gear should be used when dyno'd? 5th is the 1:1 gear right? I'm throwning mine on the dyno this weekend to get a baseline. Thanks
Old Apr 20, 2004 | 04:38 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
You not running too rich. You are fine...it's always a bit safer to be on the rich side towards redline. Aside from the one lean spike, you look good...progressively richer until about 12.0:1. Ideally, on N/A appplications its nice to see the A/F more in the 13:1 area..but this isnt too bad at all....especially with all your mods.
lapham3
Oct 7, 2022 03:15 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
NissanZcrazy
Sep 23, 2015 07:59 AM
