Added 1.20 in 1/4 after Borla Install
Old Apr 20, 2004 | 11:18 AM
Infern0's Avatar
Infern0
Angry Added 1.20 in 1/4 after Borla Install
Finally got my Borla Headers installed and to my dismay when I went to the trackI went from a 13.9 to a 14.1. Anyone know what the heck that's about? I'm trying to convince myself that it was temperature difference. 13.9 was run in December time frame.
13.9 was run stock
14.1 with AEM intake and Borla Headers installed.
Old Apr 20, 2004 | 11:26 AM
mofoz's Avatar
mofoz
try resetting the ecu and let the computer adjust to the mods. also you have to factor in driver error and track conditions. dont fret.
Old Apr 20, 2004 | 11:31 AM
C5DEMON's Avatar
C5DEMON
compare your 60's. Were they similar?
zbroyles's Avatar
zbroyles
Last time I checked 13.9 woas only 0.20 different than 14.1. I agree with ***** though, the same setup on a different day could easily be that different. A full tank versus an empty tank could make a difference close to that.
Old Apr 20, 2004 | 11:37 AM
Tex Willer's Avatar
Tex Willer
What was MPH?
Old Apr 20, 2004 | 05:05 PM
Infern0's Avatar
Infern0
lol...you're focusing on the wrong part of the story! Leave my math out of this!
Had a 2.0 60 ft. when I ran the 13.9 and a 2.1 and 2.2 the other day.
100.4 MPH with the 13.9 and 99 MPH the other day.
I haven't heard anything about this car's ECU so just to double check, unplugging the battery for about 30 minutes will reset the ECU right?
I'm not completely ruling out driver error. The only reason I'm scepticle about it though is cause I have been racing for a while now and am always very consistant. Also I ran about 5 or 6 times that night and that was the best it would do. But no one's perfect right, I could have been having an off night, and there is a significant difference in air temperature in December and April.
Old Apr 20, 2004 | 05:08 PM
jckolnturn's Avatar
jckolnturn
how about tires? do you have much more wear on them?
Old Apr 20, 2004 | 05:53 PM
peptidbond's Avatar
peptidbond
I think the people above are asking the right questions. However, the Borla headers are not know for real power. They are not equal length and many have questioned the design. On a forced induction car, it would not matter than much. However, on NA cars, many have not been thrilled. This is why so many people ate up the Nismo and Crawford headers. The design was better overall. Personally, I am pretty happy with my Crawfords, but I have only had them on since this weekend. I am dynoing on Thursday though (same dyno as before and temp should be similar). Good luck.
Old Apr 20, 2004 | 07:26 PM
Infern0's Avatar
Infern0
Yes, these definately are all questions that I've asked myself a couple times since that night at the track. There isn't too much wear on the wheels, however, since you mention it...I let 5lbs of pressure out of the rear wheels this time because I was getting a lot of wheel hop before. So I was running with 30lbs in the rear. I thought that was supposed to be a good thing though. You think?
Old Apr 21, 2004 | 01:14 PM
Dissolved's Avatar
Dissolved
ever run with just the aem? You should of before the borla install.
anyway, for now:
Put your stock intake back on and run. See if your time increases/decreased.
AEM could be causing power loss (has in the past). This way you can at least eliminate one factor.
Old Apr 21, 2004 | 01:56 PM
Infern0's Avatar
Infern0
Actually I did run with just the intake....there was no difference than before the intake.
Old Apr 21, 2004 | 02:52 PM
zxsaint's Avatar
zxsaint
Fairlady Stalker
Dissolved, is it just me or does the chick in your avatar have some huge feet?
Old Apr 22, 2004 | 01:44 PM
Balls's Avatar
Balls
hehe....
Old Apr 22, 2004 | 02:00 PM
mofoz's Avatar
mofoz
goto or search for www.technosquare.com and follow their ECU resetting instructions. The ECU doesnt always get reset by taking of the negative terminal from what i hear. The temp outside could be to blaim, as could the tire pressure. All of these can make a difference. Go out again and see how you do. I would recommend strongly resetting the ECU however. And btw that chick does have huge feet.
Old Apr 22, 2004 | 02:17 PM
Infern0's Avatar
Infern0
Yeah, will do. Is that the right technosquare? Couldn't find anything about any cars on that site.
So umm...what do they say about CHICKS with big feet?
They wear big socks too?
Old Apr 23, 2004 | 07:43 PM
Zpeed Freak's Avatar
Zpeed Freak
Try www.technosquareinc.com/350reset.htm
Old Apr 23, 2004 | 09:03 PM
Z_Pride's Avatar
Z_Pride
I feel like I'm typing in some code to a video game.
Old Apr 23, 2004 | 11:34 PM
FairladyZ's Avatar
FairladyZ
Default Re: Added 1.20 in 1/4 after Borla Install
13.9 was run stock
I wouldnt doubt you lost power. I had exhuast on my white car, got tired of the fart sound so I went back to stock. The car feels quicker now that I went back to stock.
An engineer at my old mans work, said that vehicles now are being exhuast pressured tuned (or whatever cant remember) so by changing the flow rate you could actually loose power based on how the car is tuned. Also in reality the stock muffler is already high flow, so by changing "mufflers" you are just changing the sound or tone of the vehicle and not actually power.
Not to mention the chicks like the stock sound a million times better than the fart sound.
Old Apr 24, 2004 | 05:23 AM
knuguy's Avatar
knuguy
I think you guys are missing the obvious.
DYNO BEFORE and AFTER, the only way you will see a true result!
You will NEVER duplicate a run at a track unless you are a pro.... so may vairables change from week to week in track conditions. I could see if you made the runs the same day, but if the temp changed or humidity, your car will NOT perform the same every day............You even stated your 60' was slower, thats a driver "error"
Old Apr 24, 2004 | 04:05 PM
Infern0's Avatar
Infern0
Hmmm, but dyno says the car feels a little quicker after ecu reset.....probably just my imagination though. : /
