It Cracked
Old Apr 24, 2004 | 05:16 PM
  #41
scubasteve's Avatar
scubasteve
Originally posted by JST4FN
The front center bolt is drilled at the weakest point (not a true flat surface) on the intake so it will bolt up. Then instead of using a drilled flat surface with a bolt and washer (like the bottom side or bolt near the TB) there was a concave screw used.
Thanks Mike
I was thinking the same thing when I installed my plenum. I just thought that they had reinforced that area, but I guess not. I was concerned with the uneveness of the bolt head surface to the surface of the plenum not applying even pressure. I believe that is why mine is cracked also. I just don't want to have to remove the damn thing, install stock, then re-install new I love working on my car actually.....every time I do something like this under the hood, I get some crazy idea and try tinkering with things.....a bit too much shometimes.
Old Apr 24, 2004 | 05:46 PM
  #42
Apexi350z's Avatar
Apexi350z
Charter Member #50
what about instead of using 2 post, we use all 6 posts like the factory style? that way, it will minimize flexing since it's evenly tighten down on 6 points. This is just an idea maybe Kinetix can use in the future...
is there reason that it would not work?
Old Apr 24, 2004 | 08:08 PM
  #43
all_bark's Avatar
all_bark
air restriction!
Old Apr 24, 2004 | 09:38 PM
  #44
ares's Avatar
ares
Veteran
well thats fine and dandy... but all the flow in the world doesnt help if more fail than not.
gotta find a happy medium with it.
Old Apr 25, 2004 | 08:02 AM
  #45
JST4FN's Avatar
JST4FN
He replied back to my email and actually the new plenum does have the center bolt changed to a bolt and washer (great minds think alike) and he has also stated more material in this area along with some fiberglass to help strength. I'm going to give it another shot. The bolt along should yeild some good results.
By the way even though it cracked he has been very responsive in trying to get things fixed in his design to sell a good product and that has to be worth something.
Thanks Mike
Old Apr 25, 2004 | 10:41 AM
  #46
NISMO_GUY2003's Avatar
NISMO_GUY2003
Boy I'm glad I read this post since I've had my Kinetix plenum only since about March. Went into my garage and popped the hood to look at the plenum. No cracks visible. I decided th start it up and sure enough there was a big crack from the center bolt area. I just spent the last 30-40 minutes removing the Kinetix. Thought about reinstalling the stock plenum but since the Z isn't my daily driver, I decided to just leave it apart until I can get the replacement.
Now I'm off to send an email to Kinetix about getting a replacement...
Old Apr 25, 2004 | 07:00 PM
  #47
D_Nyholm's Avatar
D_Nyholm
make sure you cover up your engine bay with a towel or something, you don't want something falling inside the engine while it is open to the elements.
Old Apr 25, 2004 | 07:38 PM
  #48
NISMO_GUY2003
Thanks for the tip!
norrix420
350Z Roadster
May 23, 2022 05:11 PM
JjL
East Canada
Jun 12, 2019 03:04 AM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
Twenty4
Jan 17, 2016 01:20 PM
tm9293
Wheels Tires
Sep 11, 2015 02:45 PM
