Ecu
Old Apr 22, 2004 | 08:39 AM
rollin350z's Avatar
rollin350z
Question Ecu
I have had my jwt popcharger for about 2 months. I just got my nismo exhaust w/crawford cats installed. should I reset my ECU or something, or will my car figure it out on its own?
If I should reset it what is the best way to do it?
Old Apr 22, 2004 | 09:32 AM
g356gear's Avatar
g356gear
Default Re: Ecu
Disconnect the battery.....depress the brake pedal a few times to get all power out of the system...and let it sit overnight. Hook it back up in the morning and you should be good to go.
Old Apr 22, 2004 | 02:55 PM
rollin350z's Avatar
rollin350z
Do you guys think i need to do it??
Any benifits from it?
Old Apr 22, 2004 | 05:06 PM
peptidbond's Avatar
peptidbond
Yea, it would probably be best. However, I don't buy the battery disconnect solution (just my opinion). I think the ECU has solid state memory (aka - Flash memory). So, it is best to follow the reset procedure in the manual.
Old Apr 22, 2004 | 08:14 PM
baekk77's Avatar
baekk77
can some post a reset procedure from manual..... I was told from the dealer that we can not reset ecu by just disconnecting neg battery on 350z.
Old Apr 22, 2004 | 08:19 PM
Phaneom's Avatar
Phaneom
Try this way.
http://www.technosquareinc.com/350reset.htm
Old Apr 22, 2004 | 09:52 PM
DaveO's Avatar
DaveO
Far be it from me to differ with a Nissan Dealer, however....
Pages EC-70 & EC-71 in the 2003 350Z Service Manual states:
"* If the battery is disconnected, the emissions-related diagnostic information will be lost after approx. 24 hours.
* The following data are cleared when the ECM memory is erased.
- Diagnostic trouble codes
- 1st trip diagnostic trouble codes
- Freeze frame data
- 1st trip freeze frame data
- System readinesstest (SRT) codes
- Test values
- Others
Actual work procedures are explained using a DTC as an example. Be careful so that not only the DTC, but all of the data listed above, are cleared from the ECM Memory during work procedures."
I've used both the battery disconnect and the accelerator reset procedure (picture from page EC-73) in the past.
DaveO
hulkout
Tuning
Sep 30, 2015 12:33 PM
speedsniper
Sep 14, 2015 08:46 AM
Twiztids4
Tuning
Sep 10, 2015 04:02 PM
