Help with Sun Automobile Hyper Ground System
Old May 1, 2004 | 10:18 AM
DM350Z's Avatar
DM350Z
Default Help with Sun Automobile Hyper Ground System
I dont know which exact locations these 5 wires hook too, anyone know where, or know of some detailed directions?
-Dave
dm350z@msn.com
Old May 1, 2004 | 01:15 PM
z327's Avatar
z327
Since the kit is universal you will have to try and hook them up as best you can.
You should run one cable to the factory body ground under the hood sensor. This is directly in front of the passenger side stut.
I would try and run one to each of the empty holes on top of the intake plenum nearest the firewall.
The other two should go to the front or driver's side of the engine, depending on where they reach.
I wrote a DIY some time back under the Tech section of this forum http://www.350zforum.com
Hope that helps.
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
