I have a base, and want to turn off the tcs
Old May 3, 2004 | 11:07 AM
thunder0880's Avatar
thunder0880
Default I have a base, and want to turn off the tcs
How can I turn off the traction control system? I am sure I am going to have to unplug something. Any suggestions?
Old May 3, 2004 | 11:13 AM
tbcz's Avatar
tbcz
You'd better duck.
The base doesn't have TCS.
Old May 3, 2004 | 11:19 AM
thunder0880
The base has TCS, but it doesnt have the options to turn it off. I am looking for a manual way to turn it off.
Old May 3, 2004 | 11:33 AM
pLacebo's Avatar
pLacebo
The Eradicator
Base model does not have TCS- if it did you would have a button to turn it off.
http://www.nissanusa.com/vehicles/Mo...0382||,00.html
Old May 3, 2004 | 11:40 AM
thunder0880
I want to drift!!
Old May 3, 2004 | 11:43 AM
VandyZ's Avatar
VandyZ
You are not driving it hard enough if you think the base has TCS.
Try going around a wet corner and give it some gas in a low gear . . .on second thought dont, you might wreck it.
Old May 3, 2004 | 11:59 AM
350zSpeedRacer's Avatar
350zSpeedRacer
Originally posted by thunder0880
I want to drift!!
I'd avoid that until you learn a few more things about your Z.
Old May 3, 2004 | 12:31 PM
ares's Avatar
ares
Veteran
haha, DONE. its off. it will forever be off. your good to go.
if during hard cornering you see a slip light come on in the dash, get your eyes checked.
Old May 3, 2004 | 12:33 PM
KrazY-2K's Avatar
KrazY-2K
Default Re: I have a base, and want to turn off the tcs
The Base model doesn't have TCS, so no worries. I should know, I own one
Old May 3, 2004 | 12:43 PM
SQUILL's Avatar
SQUILL
I want to drift!!
there is no t/c on base what is probably happening is because there is no limited slip diff in a base you cant "drift" becasue you can only break one tire loose. You will never drift in that car unless you install a LSD.!
Old May 3, 2004 | 12:59 PM
Traffic's Avatar
Traffic
This is on its way to becoming best thread ever.
The base does not have VDC or TCS or a LSD. It has an open differential. VDC is your hands, and TCS your right foot.
Old May 3, 2004 | 01:59 PM
ares's Avatar
ares
Veteran
you can force that other one to break loose. not like you CANT drift, its just a little more difficult and not quite as slippery.
Old May 3, 2004 | 02:07 PM
Fall-Line's Avatar
Fall-Line
Default hehe
Listen,
I own a base, and before I installed my LSD, I could get the car sideways very easily..
you must subscribe to the "DRIVE IT LIKE YOU STOLE IT" theory to push the car to new performance heights..
Go to a wide open area and practice..you will be surprised at what the car can do...
good luck.
Old May 3, 2004 | 02:39 PM
tbcz's Avatar
tbcz
Old May 3, 2004 | 03:10 PM
SQUILL's Avatar
SQUILL
Default Re: hehe
Originally posted by Fall-Line
Listen,
good luck.
Yeah i know you can get the car sideways but you could never drift an open diff car....not that Thunder0880 would know that anyway ha ha
Thunder my reccomendation would be to read the owners manual front to back twice over before you attempt any more driving on public streets LOL
Old May 3, 2004 | 03:24 PM
mpol99's Avatar
mpol99
Default Re: hehe
Listen,
good luck.
Yup, I used to have a '90 NON TURBO 300zx (slooooooow & without LSD) & it used to break the rear end loose without much trouble on turns, I'm sure the guy is not trying hard enough
Old May 3, 2004 | 03:25 PM
zand02max's Avatar
zand02max
Yeah, unplug that cigarette lighter and put the pipe/weed down!
Old May 3, 2004 | 03:29 PM
SQUILL's Avatar
SQUILL
Default Re: Re: I have a base, and want to turn off the tcs
HAHAHAHAHAHA ROFLMAO LOL LMAO HAHAHA!!
Old May 3, 2004 | 03:49 PM
bigern1970's Avatar
bigern1970
Default Re: Re: Re: I have a base, and want to turn off the tcs
HE has a Base Z or a Base pipe?...........I have a base z trust me..........you dont have a tcs ........nuff said
Old May 3, 2004 | 04:34 PM
Traffic's Avatar
Traffic
Driving, shifting gears and smoking a blunt all at the same time is well beyond my coordination. I can only imagine being high makes it ten times as hard.
