Cams
Old May 18, 2004 | 06:48 AM
KISS's Avatar
KISS
Default Cams
What is the difference between Nismo and Jwt? Whats better for a daily driver? What are the gains?
Old May 18, 2004 | 11:59 AM
webcarconnection's Avatar
webcarconnection
both are good for daily driving... my JWT gain 20 rwhp... I'm seen Nismo cams 15-18 rwhp... the difference is that the JWT Cams have bigger Lift...
hope this help!
Old May 18, 2004 | 03:24 PM
lovetoclown's Avatar
lovetoclown
Check with Jeff or Jason at Performance. They recomend the nismo for NA and the JWT for FI.
Old May 19, 2004 | 04:26 AM
Jeff@Performance's Avatar
Jeff@Performance
Performance Nissan
In my car and according to the dyno's we've run, the Nismos are the perfect street cam for a N/A car. You will get more low and mid range power where you drive your car the most. The JWT's have a bit less valve overlap so are great for the F/I set ups or for a N/A car that does a butt load of street racing in the upper RPM ranges. Don't take this as a rule... it's just been our experience so far.
Old May 19, 2004 | 04:52 AM
TheBigShow's Avatar
TheBigShow
jeff, what would b your ideal setup if u were doin a straight street car?
Old May 19, 2004 | 05:01 AM
Jeff@Performance
Performance Nissan
My PERSONAL opinion... JWT Popcharger, light weight flywheel of some sort (not Nismo, JUN, JWT... too heavy) high flow cats, UD pulley, and an exhaust that sounds fun. Later depending on money... Nismo cams and headers with some ECU work thrown in. You can ask 100 people this question and no 2 will agree. BUT this is mine based on what we do and what I've seen and the smiles on peoples faces.....
Old May 19, 2004 | 05:05 AM
TheBigShow's Avatar
TheBigShow
well, i appreciate u answerin .
Old May 19, 2004 | 05:42 AM
drudacris27's Avatar
drudacris27
Don't mean to go off topic, but what flywheel would you recomend for a daily driven street machine then?
Old May 19, 2004 | 07:40 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
how much do you guys charge to install Nismo cams?
Old May 19, 2004 | 01:59 PM
Jeff@Performance
Performance Nissan
Exedy.... Tilton..... waiting to see what else comes out that is between the Tilton and Nismo.
$960.00 plus $75.00 in gaskets.. and the cost of the cams.
pslamp32
Feb 8, 2017 09:07 AM
B Esquire
Sep 24, 2015 07:52 AM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
