Thermostat
Old Jun 9, 2004 | 09:21 PM
alininger2001's Avatar
alininger2001
Default Thermostat
Has anyone found a thermostat that works other than nismo? I just think a thermostat shouldn't cost 120 bucks. Can you replace the thermostat inside the housing, any thoughts guys?
Old Jun 9, 2004 | 09:25 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
So far we dont know of any others either...
http://www.performancenissanparts.co...roducts_id=263
Old Jun 10, 2004 | 06:53 AM
goldndwgz's Avatar
goldndwgz
instead of shelling out the $120 get Water Wetter...reduces cylinder head temps.....reduces coolant temp by 20-30 degrees and provides rust and corrosion
Old Jun 10, 2004 | 07:09 AM
FairladyZ's Avatar
FairladyZ
Default Re: Thermostat
The thermostat is a waste of money until you can turn the fans on early.
Old Jun 10, 2004 | 07:20 AM
alininger2001
I am going to go with water wetter/15% glycol/water in my radiator. In the past I have been able to buy temp. controlled switches. you put a temp sensor inside the ribs of thr radiator which you attach to an adjustable switch which is connected to the fans. You just set it to the temp you want and there you go. It would woek great with a low temp thermostat.
Check it out Summit Part Number PRM-18905
This should work.
Old Jun 10, 2004 | 07:26 AM
alininger2001
Kinda like a stand alone fan management system.
Old Jun 10, 2004 | 07:29 AM
FairladyZ's Avatar
FairladyZ
sweet, gonna check it out now.
Old Jun 10, 2004 | 07:34 AM
FairladyZ's Avatar
FairladyZ
D*mn, just checked it out, I would have done it but the kit starts at 160, whereas the thermostat opens at 154.
Well, what temp does the stock fans come on at?
Old Jun 10, 2004 | 07:50 AM
alininger2001
I don't beleive the fans kick on at the same temp as the thermostat, it usually higher, but I don't know.
Old Jun 10, 2004 | 08:07 AM
alininger2001
Just a couple of things to keep in mind. 1. The fans only turn on when the car is parked or going very slow. 2. The thermostat only begins to open at 154 degrees, it must get a little hotter before it fully opens. 3. The fans shouldn't kick in until the the thermostat is fully open. (which is probably around 160 degrees, b/c you don't see to many thermos that are cooler than that)
You really don't want to run your car under 160 deg. farenheit. With this nismo/ fan switch combination and the proper water to antifreeze ratio you can probably run the car at 160 degrees, a whole 20 degrees cooler!
seagrasser
Oct 11, 2015 03:27 PM
SharX59
Sep 27, 2015 09:23 AM
mzack
Mar 25, 2005 12:56 PM
