N/A Cars Getting Tuned, is it pointless?
Old Jun 13, 2004 | 07:27 AM
Ricky's Avatar
Ricky
Exclamation N/A Cars Getting Tuned, is it pointless?
I'm just wondering if any N/A Z owners who are modifed are getting their cars tuned? I have these current engine modifications:
Intake
Test Pipes
Intake Manifold
Crank Pully
Headers
and I'm wondering if it'd be overkill getting the A/F tuned, change out the spark plugs, and timing..ect.
If anyone has done it, can you post exactly what you got done, and how you felt with the results, if any. Thanks!
Old Jun 13, 2004 | 08:29 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
given those mods, I most certainly would get it tuned. How you go about doing it (E Manage, reflash, etc.) is up to you, but its a good thing to have everything working together as a unit.
I had my car flashed about 7 months ago when I had intake, exhaust, pulley, cats, Y pipe. We were able to not only stabilize the AFR throughout the rev range, but I picked up 12 hp and 11 lb feet. Car did not feel remarkably different afterwards, just ran better overall - most better throttle response, and better pull through the rev range. So far my plugs are OEM ones (car is an 04, flashed at around 10k, now at 18k)
Adam
Old Jun 13, 2004 | 10:06 AM
adanande's Avatar
adanande
i would not ever recommend Crank Pulley. that Mod is very bad i dont care who says what.
Old Jun 13, 2004 | 11:15 AM
reallyredZ's Avatar
reallyredZ
Deffinatly get it tuned. Just make sure to get it tuned after you finish your mods.
Old Jun 13, 2004 | 11:42 AM
nismo33's Avatar
nismo33
BoNe SToCK BaSe
I just went to the dyno on sat. and running very lean 14.1 A/F with the following parts:
Nismo exhaust
Nismo CAI
Helix test pipes
I'm going to get my ECU reflashed to prevent detonation on my car.
Old Jun 13, 2004 | 03:33 PM
Z1 Performance
Former Sponsor
I highly recommend getting it done on your car nismo33, as opposed to a one size fits all mailorder deal
Old Jun 13, 2004 | 04:21 PM
Zpeed Freak's Avatar
Zpeed Freak
Old Jun 13, 2004 | 05:31 PM
Speedracer's Avatar
Speedracer
Default Can a piggyback unit be used to alter fuel flow.....
just enough to richen up the mix with the slightly increased airflow possible with NA mods. For instance, is there any kind of unit available to, for example, lengthen injector pulse by 10-15%, or to just slightly alter the stock fuel maps?
Old Jun 13, 2004 | 05:41 PM
Speedracer's Avatar
Speedracer
Default please explain why you shouldn't change the crank pulley?
Don't just make a statement like this without some kind of facts/experience/follow-up. What good is it to anybody otherwise?
Old Jun 13, 2004 | 07:13 PM
UsafaRice's Avatar
UsafaRice
adanande, you should post some facts or links about this argument if you post that kind of line. I know where you're coming from because I've seen the background, but someone new to the discussion might not be able to give your argument the consideration it needs.
Old Jun 13, 2004 | 08:58 PM
BoostTed's Avatar
BoostTed
Nismo exhaust
Nismo CAI
Helix test pipes
hey good meeting you saturday..virgil right? Im sorry if I got your name wrong, I didnt get a good chance to match names to screen names. You should have told me you were going to Upgrade motoring after lunch I would have met you there, i havent talked smack to Glenn in a bit.
Old Jun 14, 2004 | 09:07 AM
KyleB's Avatar
KyleB
Default Re: Can a piggyback unit be used to alter fuel flow.....
Yes, e-manage or apexi safc units can do that. The emanage is FAR more versitale, but requires a laptop.
aarrgghh
May 1, 2022 11:04 AM
bcoffee20
Nov 19, 2015 06:39 PM
NissanZcrazy
Nov 2, 2015 06:03 PM
z33z_nutz
Sep 23, 2015 07:22 PM
