Ur Crank Pulley Noise Question
Old Jun 30, 2004 | 01:03 PM
protocav's Avatar
protocav
Default Ur Crank Pulley Noise Question
has anyone noticed any noise after the installation of the Unorthodox Racing crank pulley? it sounds like a constant squeaking belt noise. this is not the standard belt squeak, as i have my belts nice and tight.
the noise is very, very slight, but there was absolutely no noise at all with the stock pulley. you really have to listen for it, and it is nothing alarming, but i am curious to know if the noise is a characteristic of the pulley or something else.
also, when i turn on my A/C, the compressor is pretty loud, so it could just be the bearings in the A/C pulley spinning when it is off?
sorry for the rambling, but if anyone has a comment, or an opinion, please let me know.
Thanks!!
Old Jun 30, 2004 | 06:54 PM
protocav's Avatar
protocav
bueller.....?
Old Jul 1, 2004 | 04:30 AM
jpc350z's Avatar
jpc350z
Default Re: Ur Crank Pulley Noise Question
Thanks!!
An earlier thread on U/R pulleys discussed the need for the rubber (damper) on the stock pulley..I believe the consensus of opinion on the need for this damper is to reduce/eleminate noise generated by the belts that are on this pulley..Kinda like a high frequency low volume ringing sound. Perhaps that is what you are hearing..The thread was a debate about whether the stock pulley/rubber was needed to provide harmonic balance for the engine. After much debate (that may still be going on )the most logical explaination for the rubber (for me ) is for it to dampen noise..
Old Jul 1, 2004 | 05:39 AM
SandMan's Avatar
SandMan
Try tightening your belt. I had a squeaking noise on cold starts, but once I got my belt tightened it went away. Never hurts to try.
Old Jul 1, 2004 | 06:30 AM
Tim'sZ's Avatar
Tim'sZ
I have not had any problems with mine other than the belt squeaking, and that was an easy fix...
Old Jul 1, 2004 | 07:54 AM
protocav's Avatar
protocav
Default Re: Re: Ur Crank Pulley Noise Question
a high frequency, low volume noise is a perfect explanation. that must be it.
as long as i can prove (read: rationalize) that this noise is simply from the omition of the dampener, and not something more serious, i guess i am content.
thanks!
issyz
Jul 2, 2017 03:04 PM
Fixxxercask
Nov 9, 2015 11:10 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
