jwt lightweight flywheel quandry......
Old Jul 14, 2004 | 09:50 AM
G3po's Avatar
G3po
Default JWT and Rouge
When you get them both in I'd really like to hear your subjective
view of the "cement mixer sounds" as heard from inside the G35 cab. I am considering the JWT setup , just don't want the sound to be "too" loud.
Thanx
Old Jul 14, 2004 | 05:37 PM
phunk's Avatar
phunk
CJ Motorsports
the sound is embarassing, you will get used to pushing in the clutch pedel when hot chicks are next to you at stop lights. when driving its acceptable, but still extremely noticable. when it does it at idle, its obnoxious. you can clearly here it from far away, matter of fact if i walk out of the car and leave it idle, as i get closer to the car the first thing i can hear again is that noise.
with that said, its worth it anyway, a little noise never hurt anyone, and you will get used to hiding it within a couple days.
Old Jul 14, 2004 | 06:11 PM
esemes's Avatar
esemes
oem:
Old Jul 14, 2004 | 06:12 PM
esemes's Avatar
esemes
jwt:
Old Jul 14, 2004 | 06:15 PM
Gilley's Avatar
Gilley
The JWT surely look sexier than stock. It sure has a lot of screws in it. It that to aid in changing out the plate?
Old Jul 14, 2004 | 06:16 PM
esemes's Avatar
esemes
phunk hit it on the head....
its not a good sound at idle rpm (only, IMO)
i am rasing the idle tomorrow, as it only seems to make the rattle (not cememnt truck IM) at rpms of 500-700.... if i lay on the accel. pedal to raise the revs to 800, the sound is MUCH more acceptable.......
im in the air, for now, if i will keep it, or just use the race clutch instead.....
performance-wise, ths is amazing... the car REALLY responds well to this mod, and the revvs are easier to get to 5lbs of boost now (benchamrk boost # for when i really feel like im haulin')
if i sell the flywheel, i will ask for the cost to uninstall it only....
for now, it stays, and ima drive it a little....
(am now told the tilton sounds very similar, so, if its rattles, why not have 8lb derivitive rattles??)
Old Jul 19, 2004 | 04:17 AM
jpc350z's Avatar
jpc350z
Default JWT FLYWHEEL
[QUOTE]Originally posted by esemes
[/QUOTE
Please let us know how it sounds when you get the idle up..Thanks
Old Jul 19, 2004 | 04:19 AM
esemes's Avatar
esemes
will-do
(you need to add a "]" to the quote to get it to work, BTW
SMS
ps- i will have this done on wedensday(as well as other things), but am thinking it wont be able to raise much....
Old Jul 19, 2004 | 06:50 AM
ACP's Avatar
ACP
after reading posts about the flywheel sounding like a "cement mixer" I was expecting much worse..
I can barely hear the noise on mine, need to listen for it...
If it gets quiter with miles, as others noted, then I don't know if I will be able to hear it at all.
Which will be better yet
So far, with the very little driving I have done with the JWT clutch and flywheel, I am happy with it.
No more pedal effort over stock
clutch grabs in the middle of the pedal, instead of at the top like stock, which I could not stand.
And it feels very smooth....
did any of your combos come with the Nissan throwout bearing, alignment tool, pilot bushing ?
Mine didn't. I just used the my stock throwout bearing and bushing, as I have less then 3K on the car, so there is no signs of wear. But just though it should be included.
Old Jul 19, 2004 | 07:33 AM
UsafaRice's Avatar
UsafaRice
You guys are using the Gtech to measure the 0-60 times? Where did you pick it up and for how much? Also, does the stock shifter handle fit on the rogue short shifter kit?
And finally, excellent work...
Old Jul 23, 2004 | 03:14 AM
ACP's Avatar
ACP
Going to update this, take it back
It sounds like eveyone describes.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
