Name the problem,...... win a prize
Old Jul 19, 2004 | 11:57 AM
esemes's Avatar
esemes
Unhappy Name the problem,...... win a prize
okay...
another contest::
rules::
none.. jus name what seems incorrect, or rather "wrong" with this pic
prize::
pride of being named the winner of the "name the problem" game....
now, beofre you go any click, its NOT that i have a Z cover on my G either.... its a sign/symptom of a problem i am having (fixed today or tomorrow)
good luck!
Old Jul 19, 2004 | 12:11 PM
alphaz's Avatar
alphaz
Looks like you have a blue cooling hose loose on the right side of the engine bay or is that a loose grounding strap ?
Old Jul 19, 2004 | 12:15 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
No that's a grounding kit wire. Where's the belt for the pulley right above the supercharger?
Old Jul 19, 2004 | 12:18 PM
esemes's Avatar
esemes
XX
hint**** its not any blower tolerances......****
Old Jul 19, 2004 | 12:19 PM
Road Warrior's Avatar
Road Warrior
not enough clearance on the bottom of your cover for the supercharger belt
Old Jul 19, 2004 | 12:23 PM
esemes's Avatar
esemes
lol, RW......
((i wont add a strike to the total....))
Old Jul 19, 2004 | 12:38 PM
VandyZ's Avatar
VandyZ
A/C line?
Old Jul 19, 2004 | 12:41 PM
JeffR116's Avatar
JeffR116
That's a G35 Engine Bay
Durrr's Avatar
Durrr
Kinetix plenum w/ F/I?
Old Jul 19, 2004 | 12:49 PM
DrVolkl's Avatar
DrVolkl
He's got a crawford on there.
You getting belt slippage? That's my guess..
Old Jul 19, 2004 | 12:51 PM
Durrr's Avatar
Durrr
it was black so i thought it was kinetix Umm, its a readily visible problem?
Old Jul 19, 2004 | 12:52 PM
esemes's Avatar
esemes
Default NO BELT SLIPPAGES... thankfully!
heres a BIG hint.....
Old Jul 19, 2004 | 01:00 PM
mpowers's Avatar
mpowers
You'r radiator cap is oppisite of the Z? The car is over heating due to not enough colling capacity in fl?
Old Jul 19, 2004 | 01:08 PM
Road Warrior
radiator overflow hose
Old Jul 19, 2004 | 01:17 PM
esemes's Avatar
esemes
NOTICE the coolant level is WAAAAY above the "max" reading on the overflow resv.
my Nismo LT thermo has malfunctioned, and is not allowing full circulation of coolant.
Luckily, i caught this before the car overheated fully.... its at the dealership now, awaiting the new thermo (getting a new nismo, again.....) .......
kinda hard to see the problem, but i thought it was a neat game anyway...
now, to get to the thermo, well, thats another issue altogether....
Old Jul 19, 2004 | 01:24 PM
mpowers's Avatar
mpowers
crap and I most had it. Sorry to here the thermostat is stuck.
Old Jul 19, 2004 | 02:24 PM
Nismosx's Avatar
Nismosx
I gotta say besides your problem thats a beautiful engine bay especialy that supercharger.
What kind of times do you run with that? Did you dyno it? Sorry if this has already been talked about Im fairly new around here.
Old Jul 19, 2004 | 02:48 PM
ACP's Avatar
ACP
are you sure it is the thermo, and not air in the coolant lines ?
I had this problem, and I had to use the bleeder screw in the hose, to get out the air in the line.
Old Jul 19, 2004 | 02:53 PM
MIAPLAYA's Avatar
MIAPLAYA
by Nismo thermostat
Old Jul 19, 2004 | 03:02 PM
azaz's Avatar
azaz
Technically the coolant doesn't "flow" through the reservoir to help cool the engine. It is there for when the coolant gets hot and expands to go to the reservoir. When the engine cools the coolant returns to the radiator, thus the MIN and MAX marks on the reservoir. MIN is (usually) the full cold mark and MAX is (usually) the full hot mark. Anywhere in between those two marks is normal, depending on when and how hot or cool the engine coolant is when you check it.
It could be due to a bad pressure cap that the coolant is over the mark, or someone filled it too full when the engine was cold, or possible engine overheating and the coolant was pushed into the reservoir making it go over the marks. Lots of possibilities for that to happen really. But I hope everything is ok with your car and you get it sorted very quickly.
