Aftermarket 1/2 axle ?
Old Jul 20, 2004 | 02:51 AM
mjedens's Avatar
mjedens
Default Aftermarket 1/2 axle ?
Anyone making 1/2 axles?
Old Jul 20, 2004 | 06:31 AM
UnderPressure's Avatar
UnderPressure
www.driveshaftshop.com
They were suppose to be working on half-shafts for the 350z. Have you popped a stock half-shaft? What were the conditions?
Old Jul 20, 2004 | 07:02 AM
mjedens's Avatar
mjedens
I checked with "driveshaft.com" yesterday and they said they didn't have anything.
Conditions: Left the line after soaking my slicks in "VHT" at 6200 rpm's with a 200 shot. "It Hooked" !! Went approximately 6 inches and snapped the driver's side half-shaft.
Old Jul 20, 2004 | 10:43 AM
mjedens's Avatar
mjedens
You were right about driveshaftshop.com, they are developing axles for the 350z. I was talking earlier to driveshaft.com (no shop in the address) and they are not. Thanks for the info!
Old Jul 20, 2004 | 12:23 PM
UnderPressure
Glad the info helped.
What sort of time frame till they are ready? I have a feeling I will be in need of upgraded axles in the near future.
Old Jul 20, 2004 | 01:16 PM
mjedens's Avatar
mjedens
2 to 4 weeks!!
I've heard that on September the 11th there is going to be a Nissan Drag Day somewhere in KY ! Do you plan on going and if so do you have any information about it?
Old Jul 20, 2004 | 03:04 PM
randyshemin@comcast.'s Avatar
http://forums.maxima.org/showthr
http://www.fastmaxima.com/MEET.htmead.php?t=320643
Mike,
Check out these two links for info. The club sent this out on June 28. Hope you're getting your ZNEWZ!
Sept. 11 in Bowling Green, KY.
Randy
Old Jul 20, 2004 | 03:22 PM
mjedens's Avatar
mjedens
Thanks Randy,
I am getting ZNEWZ and I thank you for it! My problem is that the 2 links you talk about go nowhere when I click on them. Bowling Green isn't that far so I'm sure I'll attend if "the car" is in one piece come September!!
Old Jul 20, 2004 | 03:24 PM
Mr B's Avatar
Mr B
If I was to put thicker axles in the rear, are there any disadvantages at all in a drift/road racing car that might wanna try drag racing too? Besides maybe a little more weight?
Old Jul 20, 2004 | 04:09 PM
Originally posted by mjedens
Thanks Randy,
Try later Mike, their forums are "down".
Old Jul 20, 2004 | 05:48 PM
mjedens's Avatar
mjedens
Mr B,
IMO, I wouldn't spend the money unless you are going to do "more" than try drag racing! This is the first time I broke an axle and it was while using slicks with only 8 lbs of pressure and a large shot of n2o. My suspension is also set to have all the weight shift to the rear so I would never attempt to use my setup for road racing.
Old Jul 20, 2004 | 07:49 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
what exhaust are you running mjedens...
Old Jul 20, 2004 | 09:19 PM
Elitemotion's Avatar
Elitemotion
brian... more depends on your hp .. its the take offs that will brake an axle..
axles usually only brake on slicks as it won't let you spin your wheels as much which than puts great stress to your axle.
there is driveshafts for drifting also though that you might look into.. pretty much it allows it to bend more so it doesn't vibrate the rest of the parts so it last longer
Old Jul 20, 2004 | 09:51 PM
JimRHIT's Avatar
JimRHIT
congrats on breaking the halfshaft mr. edens i envy your torque
what kind of short times were you pulling?
Old Jul 20, 2004 | 11:43 PM
Mr B's Avatar
Mr B
Thanks mjedens and Brian. I figured that I wouldn't break it just from drag racing a few times, but just in case for the future. If I do have massive power, I wanna be sure I can put it down to the pavement with slicks so axles sounded like a good idea. Then I realized that slicks usually come in 15's and there's no ways I can fit anything smaller than a 17" over my rear brake. Eh, money saved I guess.
Old Jul 21, 2004 | 02:02 AM
mjedens's Avatar
mjedens
Jason,
Stillen Exhaust with test pipes! I bought a Stillen back when they were the only choice and have never regretted it. My test pipes have cut outs on them.
Brian,
16" Weld Pro Star XP"s will fit over Brembo Brakes.
Old Jul 21, 2004 | 12:00 PM
Elitemotion
he has the big A$$ endless rotor brakes that won't that or get 17's and grind down some truck tires haha
Old Jul 21, 2004 | 01:02 PM
Mr B's Avatar
Mr B
I think they make 17" drag radials, right? Still not slicks though.
Old Jul 22, 2004 | 11:38 AM
Elitemotion
save your old bald tires and soak them in VHT i'm sure sooner or later someone will make slicks in 20's
Old Jul 24, 2004 | 12:19 AM
Mr B's Avatar
Mr B
Yeah right.
