cat install question
Old Jul 30, 2004 | 03:39 AM
BrImSt0ne's Avatar
BrImSt0ne
Default cat install question
are there any gaskets that i will need when i install new cats? I looked at the stock cats and it looks like there is some type of gasket there. Can I reuse those if thats what that is? THX IN ADV!!
Old Jul 30, 2004 | 07:51 AM
protocav's Avatar
protocav
you can reuse the stock gaskets.
Chad
Old Jul 30, 2004 | 08:05 AM
BrImSt0ne's Avatar
BrImSt0ne
thx chad. glad to see my SD boys are lookin out for me! If i dont see you at the gtg tuesday i'll see you at either P&O's or the dyno day. thx again!!
-Tre'-
Old Jul 30, 2004 | 08:08 AM
MIAPLAYA's Avatar
MIAPLAYA
You can re-use the stockers but I ususally get new ones. Just in case you know. It would suck to have to take the cats back off later if they blow out.
Old Jul 30, 2004 | 08:26 AM
BrImSt0ne's Avatar
BrImSt0ne
Where can i get new gaskets from?
Old Jul 30, 2004 | 08:34 AM
MIAPLAYA's Avatar
MIAPLAYA
You can get new stock ones from a dealer. Or maybe Crawford or another header or test pipe maker may have some better ones.
Old Jul 30, 2004 | 09:00 AM
BrImSt0ne's Avatar
BrImSt0ne
thx
Old Jul 30, 2004 | 10:33 AM
mzack's Avatar
mzack
Those Stock gaskets should not blow out and the new ones will be the exact same. I wouldn't worry about them blowing out. I have never heard of that happening. I reused my stock gaskets and have had no issue.
Old Jul 30, 2004 | 11:03 AM
PoWeRtRiP's Avatar
PoWeRtRiP
the stock gaskets are metal. its difficult to blow them out. just reuse them. i had to get new gaskets when i put my injen on and they were like $7 each from nissan
Old Jul 30, 2004 | 12:14 PM
BrImSt0ne's Avatar
BrImSt0ne
$11 & $15 each at a dealer here.
Old Jul 30, 2004 | 04:36 PM
G3po's Avatar
G3po
Default stock gaskets
I've had mine in and out twice, and no leaking. They are pretty robust multilayer metal and should be re-useable a few times.
Old Jul 31, 2004 | 05:59 AM
Steel Heals's Avatar
Steel Heals
-Tre'-
Another San Diegan here...when and where is the dyno day? I'd like to dyno mine with the mods I've put on.
Regarding the gaskets, it's true, you probably can reuse them. Just to be safe, though, I bought new ones from Performance Nissan prior to installation of the new exhaust system. The manifold gaskets and the manifold to cat gaskets were on back order...took about 2 weeks to get them! None of the local dealerships had them, either.
Old Jul 31, 2004 | 07:06 AM
BrImSt0ne's Avatar
BrImSt0ne
check your PM's
Old Jul 31, 2004 | 09:11 AM
350xfire's Avatar
350xfire
Don't worry about the gaskets. They are metal and hard to screw up.
I just did cats and headers and re used the old w/out problems.
Old Jul 31, 2004 | 12:38 PM
BrImSt0ne's Avatar
BrImSt0ne
thx for everybody's inputs. just finished cat install. not too bad for my first time. took me about 3.5hrs w/lift. had some really stubborn bolts so that took most of the time. car definately feels like it breathes better.
Old Jul 31, 2004 | 02:44 PM
Steel Heals
Which cats did you get?
Old Jul 31, 2004 | 05:57 PM
BrImSt0ne's Avatar
BrImSt0ne
kinetix hf cats
Old Aug 2, 2004 | 05:02 PM
blueg35c's Avatar
blueg35c
I 'm thinking about installing my Kinetix cats this weekend. Do you need 2 people to install it? If not, how do keep the bolt from turning as you tighten it?
thanks
Old Aug 7, 2004 | 07:46 AM
350xfire's Avatar
350xfire
thanks
You need (at least I needed) 2 people just to tighten 2 bolts. That's it, about 5 minutes. I tried everything to do it myself, but found it too hard to do.
seagrasser
Oct 11, 2015 03:27 PM
Ace2347
Sep 22, 2015 03:12 AM
