Crane Cams Update
Old Aug 5, 2004 | 08:32 AM
  #41
L.A. Roadster's Avatar
L.A. Roadster
That's the story I've been hearing from Performance Nissan for the last 9 days.
The JWT's went in and nine days later, they still haven't gotten the car to run with out stalling. They say you can't adjust the idle on the 04. (I wish they would have mentioned that ten days ago)
I even called Jim Wolf, and Jim told me the same thing.
Old Aug 5, 2004 | 08:54 AM
  #42
bwzabodyn's Avatar
bwzabodyn
Um, I think wesman is right - you can have the dealer up your idle rpm using Consult...
Hopefully guys I will have some information late in the day tomorrow... cross your fingers...
1. bzabodyn
2. timrod1001
3. zimbo
4. dnahas
5. 03BLKSETE
6. stx
7. PoWeRtRiP
8. was wesman
9. Protocav
10. G3po
11. x350Zx
12. zillinois
13. aceman
14.
15.
etc..
Old Aug 5, 2004 | 09:05 AM
  #43
L.A. Roadster
Exclamation
I wish it were that simple, but I'm pretty sure that Performance tried that the first day.
I've spoken with Jim Wolf (personally), the guys at Technosquare, and Jason at Performance nissan. They all say the same thing.
If you have an 04, I would NOT recommend installing cams. I don't want anyone else to get burned like I'm getting right now.
Either I or they (Performance Nissan) will post the entire story in a separate thread once they get my car back to me in running order.
Old Aug 5, 2004 | 09:10 AM
  #44
L.A. Roadster
Wink
bwzabodyn,
Sorry if it sounds like I'm trying to put a damper on your group buy. I'm just trying to share my experiences with the forum so that no one else has to learn the hard way.
Old Aug 5, 2004 | 09:12 AM
  #45
kopo's Avatar
kopo
Interested as well, waiting for more info
Old Aug 5, 2004 | 09:22 AM
  #46
was wesman's Avatar
was wesman
Sorry to hear about your issues, but I assure you that I was sitting there when my tech raised my idle RPM's from 500ish to 750. I can't explain to you how he did it or what he did....but it definitely happened.
--wes
Old Aug 5, 2004 | 09:31 AM
  #47
G3po's Avatar
G3po
Default idle with CAMs
Is it possible that the magnitude of IDLE increase is "more limited" on the 2004 ECU program. Is it possible that they were not able to raise the idle TB positon enough to get the desired idle?
Old Aug 5, 2004 | 10:14 AM
  #48
ElvishasaZ's Avatar
ElvishasaZ
perhaps that inability to affect or raise the idle on 04's is not across the board. There may be different versions or at least earlier 04's where this was not an issue. Just a thought.
Old Aug 5, 2004 | 10:37 AM
  #49
bwzabodyn's Avatar
bwzabodyn
this is not a Group Buy, just an interest thread that I will use in the future to get a GB started... so no hard feelings - the information you are giving us is appreciated, actually, because if there are any issues, I definitely don't want to hold anyone back from gaining information that may be vital to helping avoid said issues...
1. bzabodyn
2. timrod1001
3. zimbo
4. dnahas
5. 03BLKSETE
6. stx
7. PoWeRtRiP
8. was wesman
9. Protocav
10. G3po
11. x350Zx
12. zillinois
13. aceman
14. kopo
15.
16.
17.
18.
19.
20.
etc..
Old Aug 5, 2004 | 12:04 PM
  #50
zimbo's Avatar
zimbo
I'm pretty sure that what you're talking about is the so-called 2004.5 ECU that Technosquare has not yet cracked (or hadn't last time I checked). The 2004 ECU can indeed be modified by Technosquare and with the Consult.
--Steve
Old Aug 5, 2004 | 12:28 PM
  #51
gould2000's Avatar
gould2000
I believe it has to do with whether your o4 is a ULEV (ultra Low Emissions Vehicle) or not. Technosquare has some info on their website, on which O4's were ULEV and which ones were not. You can determine this by some info on the ECU labeling according to their website.
Old Aug 6, 2004 | 03:01 PM
  #52
mpol99's Avatar
mpol99
Holly $hit!! If the price is under $700!!!! My installation will be free (close family member a very experienced Nissan tech), so this is VERY tempting!!! If it adds enough power, I will jump on this!!!
I have a stock Z & I told myself I wont mod, but this will put me over the edge, hehehe. If it ads good power, I'm IN!
Old Aug 7, 2004 | 10:54 AM
  #53
SR20DEN's Avatar
SR20DEN
If they make these cams to exact OE tolerances so that we don't have to re-shim then I am interested in them for my Maxima. However I may want something a little more aggressive.
I charge $650 for cam installs that don't require new shims. And the job takes me about 12 hours on the VQ35 Maxima.
Old Aug 7, 2004 | 12:12 PM
  #54
VQ35Kompressor's Avatar
VQ35Kompressor
Post more info please...need to know lift and duration...
Old Aug 7, 2004 | 12:42 PM
  #55
John@Victory's Avatar
John@Victory
matt (sr20den) these might be the ones your installing in my car.....
im interested
as for telling if you have an ecu that wont work with the cams...if your o2 sensors have 5 wires instead of 4 then the cams wont work
Old Aug 9, 2004 | 06:25 AM
  #56
bwzabodyn's Avatar
bwzabodyn
I'm about to get back with Dave in a few minutes so hopefully he'll have some good news for me...
1. bzabodyn
2. timrod1001
3. zimbo
4. dnahas
5. 03BLKSETE
6. stx
7. PoWeRtRiP
8. was wesman
9. Protocav
10. G3po
11. x350Zx
12. zillinois
13. aceman
14. kopo
15. mpol99
16. SR20DEN
17. tonylittell
18.
19.
20.
etc..
Old Aug 9, 2004 | 04:26 PM
  #57
John@Victory
no news?
Old Aug 9, 2004 | 07:58 PM
  #58
bwzabodyn's Avatar
bwzabodyn
I finally found out the person I need to speak with that is heading up development - the only problem is that when I was directed to his line it went directly to his voicemail which said "I will be out of the office on 8/9 will return 8/10" - so I'll try once again tomorrow... I'm trying guys...
Old Aug 15, 2004 | 04:32 PM
  #59
kopo's Avatar
kopo
any updates on this, its now 8/15
Old Aug 23, 2004 | 09:23 PM
  #60
ColecatZ's Avatar
ColecatZ
damn, how did I miss this thread for so long.... I'm interested pending specs (like most everyone else)
Thanks in advance
