DIY Questions
Old Aug 6, 2004 | 05:12 AM
FRIT-Z's Avatar
FRIT-Z
Default DIY Questions
I just bought the following bolt ons...wondering how many I can install myself w/ help from my son...I have ramps and access to all the tool I will need.
Crawford plenum and strut bar
Crawford HF cats and Injen straight tip duals
B&M short shifter
UR Crank pulley and belts
Samco radiator hoses
Any advice is appreciated.
Fritz
Old Aug 6, 2004 | 05:16 AM
moog's Avatar
moog
All should be relatively simple if you're mechanically inclined. Might have some difficulty w/ the high flow cats because of space constraints & the bolts. Other than that it should be no problem.
Old Aug 6, 2004 | 01:21 PM
KA24DET's Avatar
KA24DET
test only...
Old Aug 6, 2004 | 01:47 PM
lorinserbenz's Avatar
lorinserbenz
Default Re: DIY Questions
B&M short shifter
Fritz
Have an exhaust shop or tech put tech cats on. If you car has a few thousand miles on it the bolts will be hard to remove. Everything else you have is easy to install.
Old Aug 6, 2004 | 03:48 PM
ChrisMCagle's Avatar
ChrisMCagle
B&M short shifter
Fritz
These are all things that you can do yourself. The only 2 that you will have problems with are the Pulley and the Cats. The pulley bolt is a bitc# to remove and the cats are difficult due to the extremely cramped working area (it took me close to 8 hours to do the cats myself with the car on jackstands).
Good Luck!
-Chris
Old Aug 7, 2004 | 07:30 AM
350xfire's Avatar
350xfire
Default Re: Re: DIY Questions
Cats are not that bad. Just get a long breaker bar and someone to help you tighten 2 bolts. Those two are easy to tighten if someone gets under the car and the other person gets to them from the top. You will need a 24" extension for the 2 bolts. I would estimate about 2-3 hours on the cats.
Pulley, I have not done.
Everything else loos easy.
Old Aug 7, 2004 | 07:57 AM
ChrisMCagle
Default Re: Re: Re: DIY Questions
Yeah, I guess 2 people would help on the cats install. I did it all myself which is why it took so long.
-Chris
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
