Please Help Me Engine Misfire
Old Aug 10, 2004 | 05:24 PM
Zmego1985's Avatar
Zmego1985
Default Please Help Me Engine Misfire
I need someones help i have a engine cylinder misfire i dont know why. Someone please tell me why this could be happening. Also i have headers on my car will nissan void my warranty now?
Thanks Glen
Old Aug 10, 2004 | 05:32 PM
j's350z's Avatar
j's350z
Do you feel the engine misfire or just have a P300 code on your engine light... I am 99% sure you just have the code with no misfire. These computers are very sensitive to mods and thats most likely what it is from. Do a search on here to reset your light and see if you get it again....
Jason
MRC Motorsports
www.racemrc.com
Old Aug 10, 2004 | 05:41 PM
Zmego1985's Avatar
Zmego1985
No the engine is running fine autozone shut off the light and its not back on. But they said its saying its misfiring and it was the P300 code and i saw it. So i have nothing to worry about? Also is it still safe to get a technosquare reflash now.
Thank you Glen
Old Aug 13, 2004 | 04:23 PM
PhoenixINX's Avatar
PhoenixINX
Interesting... We have ONLY seen this code on cam'd cars.
Might want to get yours into the dealer. Doesn't sound good.
Old Aug 13, 2004 | 05:31 PM
Zmego1985's Avatar
Zmego1985
I reset the ecu and it hasnt come on since. Its been over 150 miles and the spark plugs are perfect, and i dont feel a misfire.
Glen
Old Aug 13, 2004 | 07:59 PM
PhoenixINX's Avatar
PhoenixINX
Interesting.
Old Aug 13, 2004 | 09:23 PM
Zmego1985's Avatar
Zmego1985
Im heavily modified now i think this is why it went on. I have a apexi cold air intake, unorthrodox racing pulley, HKS grounding kit, crawford plenum, crawford cats, crawford headers, and Injen ses exhaust. Next mod to get is my ecu reflashed from technosquare so i can get the max performance.
Glen
Old Aug 14, 2004 | 08:48 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
I get it all the time and I have no cams......
every time the fuel cut off is hit, well not every time but every other time, it will throw a multi cylinder misfire...
Old Aug 14, 2004 | 03:01 PM
redls1's Avatar
redls1
I have also thrown this code and have no cams!
Old Aug 14, 2004 | 04:14 PM
luanda's Avatar
luanda
I had the NISMO Headers and the CEL has never come on. Did you hit the engine cut-off leading up to the P300???
If you did maybe that's it and you'll be fine. Maybe that's just wishful thinking. Have you recently dyno'ed? Checked your A/F Ratio??
Old Aug 14, 2004 | 04:19 PM
redls1's Avatar
redls1
Actually mine came on when my kinetix intake was leaking.
Old Aug 14, 2004 | 10:35 PM
Zmego1985's Avatar
Zmego1985
It has not come on since. Im gonna be dynoing and i will get my AF ratio to send to technosquare. So i can get a perfect setup for the crawford package.
Glen
Old Aug 14, 2004 | 11:30 PM
Jason@Performance
Performance Nissan
anyone who has ever hit their rev limiter they would get this code...
Old Aug 15, 2004 | 01:59 PM
PhoenixINX's Avatar
PhoenixINX
Bang it all the time and never had this code.
Old Aug 15, 2004 | 02:21 PM
MIAPLAYA's Avatar
MIAPLAYA
Never had this code either. Hit rev limiter twice. Interestingly enough I did get it frequently on my Spec V after I installed the header. Sometimes my car would run rough and throw the code.
Old Aug 15, 2004 | 07:00 PM
chazzg's Avatar
chazzg
Ok I don't want to Scare you, but here is my Experience with this. I had a clicking noise when my Z was at idle, and I was getting a misfire code (p0306 # 2 misfire) to make a long story shorter, after months of trying different things I found that there was Oil on my #2 spark plug. So I replaced it hoping that would fix the misfire. At the same time Nissan did a compression test and found that my # 2 was at 90 where the others where at 120 (which is where they are supposed to be) so I was down about 30% on my #2.(and still put down 250 on the dyno a week before)
Nissan thought it might be fuel wash out, so I drove the car for a few more weeks to see of it got better or worse. It got worse and the CEL came back on (same Code).I took it back to the dealership. Nissan did another compression test. It was Down about 40% this time. So Nissan thought I had a bad ring, so at this point they did a top down tear down on my engine and ordered new rings and new pistons.
Now here comes the scary part, When they pulled the engine to put in the new parts they found out that the # 2 rod was bent as well. This started a warranty issue, but that has been resolved now. My was in the shop for over 6 weeks.
If you have any questions PM me
Old Aug 15, 2004 | 08:02 PM
Zmego1985's Avatar
Zmego1985
I took out my plugs their all clean and the light has not come on since hopefully im good to go.
Thanks Glen
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
