Switching a Auto Tranny to a Manual
I have a 04 350z Automatic transmision. I would like to switch to a manual. Should A. Go to a nissan dealership and have a manual transmision put in. Or B. Get a new Z with a manual transmision. Cost is an issue.
like shinz said, i am guessing it would be cheaper and much easier to sell it and get a 6mt. i know they do swaps on mustangs but they are able to hit the salvage yards for parts.
not sure how much z trannys and 6mt ecu's go for. other misc parts and then throw in the labor charge of doing the swap.... imho, save yourself the headache.
You have no idea how huge a project this would be. Here are just some of the things you would need to buy:
Tranny
Clutch and flywheel
clutch pedal and hydrolics
Drive Shaft (possibly)
Rear end gears
M6 ECU
Center console
Just sell your car and buy and M6
Tranny
Clutch and flywheel
Rear end gears
M6 ECU
Center console
Have you thought of doing the Stillen Valve body upgrade?
I am not to thrilled with the manumatic mode myself. I thought about getting a 6mt but I cant stand shifting in traffic.
Upgrading the Valve body and getting the L spec ECU flash might make you want to keep the 5at
Originally posted by Jason@Performance
All the parts will run you around $3000 plus install...
done to a few G35's already...
good luck
I was one of those guys that bout a sports car auto (my 99m3) I decided to change it over to 5 speed.Let me just tell you,Its a nightmare.And the BMW has more space to work with.Theres just a lot to it.
not for nothing, but when it comes time to sell the car. Id walk away immediatly if I found out the person had swapped the tranny out. it would just worry me; I know its probably not as bad as someone that swapped internals of the engine, or gearing, or even flywheel and clutch upgrades.
but honestly Id be a little worried about the person that paid 3000$ plus labor(probably another 500-1000) to have it done.
if you sell yours and buy used equal to yours, youd probably lose less than 3500.
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
