Nismo Ground Wire Install
Old Sep 14, 2004 | 03:59 PM
mbonanni1856's Avatar
mbonanni1856
Default Nismo Ground Wire Install
My Nismo Ground Wire Kit came with no instructions except where each wire is supposed to go. This should be good, but I have no clue exactly where i am supposed to bolt these things. Does anyone have pictures or can tell me where the exact mounting points for all the wires go. Thanks.
Old Sep 14, 2004 | 07:51 PM
ragtopz's Avatar
ragtopz
how many pages of instructions did you get? i got 4 pages (2 sheets printed front and back)with my wires. it showed exactly which bolt it goes to.
i can post what i got if it is more than what you were given.
let me know.
Old Sep 14, 2004 | 09:29 PM
mike_vegas's Avatar
mike_vegas
thats going to look nice mike.
i would say blot them to the biggest hunks of steel i could find in the car (i.e. block, frame ect.) that will give you the best ground. but remember make it look good.
Old Sep 14, 2004 | 10:55 PM
mbonanni1856
ragtopz - Yeah that would be great. I didn't get any instructions except for what was on the back of the package. Which is pretty much nothing. Thanks.
mike_vegas - Yeah hopefully it should look good. All of the ground wires actually connect to the negative battery terminal with this kit instead of the frame and stuff. Are you going to go to the open track day a week from this coming Sat.?
Old Sep 14, 2004 | 11:57 PM
ragtopz's Avatar
ragtopz
Default here you go
the engine bay in the photos is actually that of a g35, but the install is the same. here are the 4 pages. good luck. sorry had to rotate the pics for them to fit the posting parameters.
Old Sep 14, 2004 | 11:59 PM
ragtopz's Avatar
ragtopz
Old Sep 15, 2004 | 12:00 AM
ragtopz's Avatar
ragtopz
Old Sep 15, 2004 | 12:01 AM
ragtopz's Avatar
ragtopz
Old Sep 15, 2004 | 12:09 AM
ragtopz's Avatar
ragtopz
one snag that i had that maybe i can save you from... (then again, you are probably smarter than i am).
anyways, for that battery terminal adapter, make sure that the stock clamp is seated ALL the way on the bottom of the adapter or else it will be VERY loose. i thought i had it all the way down, but there was still a little lower it could have gone. the stock clamp was able to spin on the adapter. i just lowered it a bit more and it was able to clamp securely.
also, this kit seems to have very little slack. so it seems it isnt really made to be a blingy set. i figured that if i couldnt make it blingy, that i would try to hide the wires as much as possible. i am probably the only one dumb enough to do that. anyways, here is a pic of the way i did mine:
Old Sep 15, 2004 | 12:12 AM
ragtopz's Avatar
ragtopz
oh yeah, in the instructions it doesnt really say how the grounding wire gets into the battery area. here is how i did mine:
Old Sep 15, 2004 | 08:16 AM
mbonanni1856
Sweet. Thanks a lot. That should do the trick. Did having the engine cover off make the install alot easier?
Old Sep 15, 2004 | 11:27 AM
mike_vegas's Avatar
mike_vegas
ya ill be down there, i dont know if i will run or not, i racked up a $250 cell phone bill while i was in florda so im kinda low on cash but well see
Old Sep 15, 2004 | 02:55 PM
mbonanni1856
Cool well at the most it will only be $10 to watch. Bring any friends who might be interested as well.
Old Sep 16, 2004 | 12:10 AM
ragtopz's Avatar
ragtopz
you pretty much have to remove the cover to get at the mounting points. it is pretty easy though and you dont have to remove the strut bar if you use a 10 mm closed end wrench for the nuts under the bar.
Old Sep 16, 2004 | 08:44 AM
mbonanni1856
Yeah I realized that after taking a closer look at the instructions. Tnanks again for those.
nanotech
Oct 2, 2015 05:02 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
