Difference between VQ35 and VQ35DE?
Old Oct 1, 2004 | 04:23 AM
illycut's Avatar
illycut
how can different head gaskets not effect compression ratio? that doesnt make since, unless they're both the same size and one is just stronger.
Old Oct 1, 2004 | 07:14 AM
sausage5000's Avatar
sausage5000
alti and 350, same ratio. maxima heads will raise the compression.
Old Oct 1, 2004 | 09:18 AM
sausage5000
last gen maxima heads from the 3.0 engine.
Old Oct 1, 2004 | 03:09 PM
IceY2K1Max's Avatar
IceY2K1Max
Same thickness or more likely the difference is negligible, so CR change is less then a 10th and Nissan still says 10.3:1 on both motors.
Nismo one is 0.7mm thick, anybody know the Z gasket thickness?
Old Oct 1, 2004 | 04:32 PM
Jun's Avatar
Jun
that whole diagram thing is pretty silly because altimas dont have carberators to my knowledge, and i know the altima has variable valve timing. The only difference i see between the two engines is the intake methodology, and compression according to some replys ive gotten
the 350z also has variable valve timing
Continuously Variable Valve Timing Control System (CVTCS)
Old Oct 1, 2004 | 09:51 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
when people post please research your facts so we can make this a very educating post, no one makes a rear wheel drive SUV crossover, thats just dangerous, i think Sz28r is correct in saying the SUV's are FWD or AWD, and obviously the z is rear wheel.
Dude....I am laughing....YOU are the one posting inaccurate information!
The FX35 is a rear wheel drive crossover SUV (AWD is an option on the FX35, and standard on the FX45)....not FWD as you posted.
Old Oct 1, 2004 | 11:23 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
ALL the VQ35DE powered cars have CVTCS
Old Oct 3, 2004 | 08:58 AM
Jun's Avatar
Jun
i know, i'm just saying that the 350z has it, since the guy thought the Altima had it and the 350z didn't.
Old Oct 3, 2004 | 01:03 PM
illycut's Avatar
illycut
gq_626
my bad, i posted wrong info
but i still think its a dumb idea to have a RWD SUV crossover, didnt think any company would do that
Old Oct 4, 2004 | 08:57 AM
G3po's Avatar
G3po
Default SUV RWD
gq_626
FYI You wil find this general statement to be true.
a) virtually all SUVs with "transverse" mounted engines are Front Wheel drive with rear wheels engaged for AWD (if optioned) operation on demand. For example an Acura MDX, Honda Pilot, etc.
b) virtually all SUVs with "longitudinal" mounted engines are
" Rear" Wheel drive with front wheels engaged for AWD (if optioned) operation on demand. For example an Infintiti FX35, Ford explorer , Chevy Suburban, etc etc.......
Old Oct 4, 2004 | 10:15 AM
mp3car's Avatar
mp3car
so you guys are saying the cams, rods, pistons, head profile, are all the same on all VQ35DEs??
Old Oct 4, 2004 | 10:44 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
yes....and the part numbers all match up.
Old Oct 4, 2004 | 11:38 AM
IceY2K1Max's Avatar
IceY2K1Max
Now....who's going to start figuring out what VQ40 parts are interchangeable?
Old Oct 4, 2004 | 12:17 PM
illycut's Avatar
illycut
haha i dont know, i got to work on a VQ35 first
Old Jul 29, 2020 | 04:16 AM
badchoicez350's Avatar
badchoicez350
Thanks, I'm going to take your word for it. Got a used altima VQ b/c my z motor was shot right after driving it off the lot. Didn't know the differences, so now I'm going to swap heads and internals into the original block.
Old Mar 22, 2021 | 07:48 AM
dopsdad's Avatar
dopsdad
Default Share your experience!
So this is a great opportunity to tell everyone what you found. I know for certain there were minor differences which accounts for HP variances between VQs, but what I still don't know after hours of searching is if I can use the block only from a maxima, pathfinder, etc., in my 350Z. I don't mind swapping all my internals, heads, harness, and other accessories, I just need to to replace the block. Since this is your last post indicating you purchased an Altima VQ, what did you find out? Did it work? Did you need modified mounts?
Old Mar 22, 2021 | 07:49 AM
dopsdad's Avatar
dopsdad
Along those same lines, has anyone ever used helicoils to fix a stripped head bolt hole?
Nabice
Apr 2, 2016 08:05 AM
Zorgazm
Jun 4, 2012 03:49 PM
eyecon7
Feb 24, 2008 01:26 PM
CHORO44
Jul 6, 2004 07:59 PM
