~!DIY!~ Make/Install your own grounding kit for under $40 bucks
Old Oct 27, 2002 | 09:11 PM
Scafremon's Avatar
Scafremon
Originally posted by phreezee
What exactly does Skidazzle mean by this... doesn't this discredit everything in the thread that you're referring to?
Skidazzle was joking around.
Old Oct 28, 2002 | 12:20 AM
alphared's Avatar
alphared
how come you kept the stock ground, why not replace that with the 4awg too??
Old Oct 28, 2002 | 02:14 PM
Shalashaska's Avatar
Shalashaska
VQRacer,
Do you know what length of wire you need instead if you choose to use the copper grounding point as mentioned by someone instead of where you decided to attach the wire? Thanks.
Old Oct 28, 2002 | 02:18 PM
SKiDaZZLe's Avatar
SKiDaZZLe
Charter Member #34
Originally posted by Shalashaska
VQRacer,
should be around 21".. atleast thats what mine is.
m
Old Oct 28, 2002 | 04:57 PM
Enforcer's Avatar
Enforcer
Excellent job Victor!
Enforcer
Old Oct 28, 2002 | 05:01 PM
Enforcer's Avatar
Enforcer
Originally posted by rouxeny
Hey Victor, nice job. Thanks for the writeup. My only problem is that I don't own some of the basic tools that you mention, nor do I know anybody who does. The wrenches and all aren't a problem, it's more the crimper. I'm sure I can find a way around this.
Try Auto-Zone or the like, sometimes they have tools you can use or an electrical/electronics supply, they may even crimp it/solder it for you.
Enforcer
Old Oct 29, 2002 | 04:18 AM
insaneamine's Avatar
insaneamine
Inventor
Z-Xtreme.com
Thumbs up Great DIY!
Hey Victor,
Thanks for the excellent post!
I will be picking up the supplies Friday. Operating on Saturday.
Old Oct 29, 2002 | 07:32 AM
Shalashaska
VQ,
Where did you get the lug that attaches to the battery, not the 9 others you mention?
Old Oct 29, 2002 | 04:34 PM
Intrepid's Avatar
Intrepid
Originally posted by fdao
For the HKS kit, you have to go to the Optauto web site and do a search for HKS earthing kit. You'll find it. For the hyperground kit, go to the sunauto web site.
Still no go. Can't find it. Anyone have any LINKS to these grounding kits? Thanks!
Old Oct 29, 2002 | 04:58 PM
ares's Avatar
ares
Veteran
ok, well since I havent seen anyone else ask it I will.
any comments on the possibilities of that exhaust O2 sensor ground?
and if I understood it right, the ground is really just useful since it is coupled with wires. helping them keep a steady current and sheild it from interference.
is that about right?
Old Oct 29, 2002 | 05:00 PM
Intrepid's Avatar
Intrepid
Thanks VQracer.
Old Oct 29, 2002 | 06:37 PM
ares's Avatar
ares
Veteran
ok... I read it again, so the engine just produces less noice from better grounding, which makes the signals to the ECU cleaner. I think...
but still, any plant to toss the Z on a lift, and soder a cable to the exhaust near the Air sensor and then run it to the frame somewhere near there? that would accomplish the task right?
Old Oct 29, 2002 | 06:52 PM
ares's Avatar
ares
Veteran
see I must still be confused, cant you just run the wire to any part of the frame and use that as ground? or does it have to go to the engine compartment?
or do you mean just running from the exhaust to the frame is too long? not sure where the O2 sensor is positioned in relation to the frame.
Old Nov 1, 2002 | 09:54 PM
alphared's Avatar
alphared
what kind of heat shrink did you use? does the engine heat affect it?
Old Nov 2, 2002 | 06:43 AM
LowFuel's Avatar
LowFuel
Hmm Im not seeing pictures anymore on this thread, and the photo album also says emtpy... wassap?
Old Nov 3, 2002 | 11:04 AM
Shift_Speed's Avatar
Shift_Speed
lets get them pics back up there.... and one quick question... don't flame on me guys.... whats a ground system and whats it do????
Old Nov 3, 2002 | 07:28 PM
articfury's Avatar
articfury
Charter Member #55
If you reread the thread you will find it explained, multiple times IIRC.
JD
Old Nov 10, 2002 | 07:18 AM
  #38
rouxeny's Avatar
rouxeny
Hmm, I now have a grounding system, but my installation has been foiled by one stupid thing. I have no socket wrench, nor do I know anybody near who does. This is not good.
Old Dec 1, 2002 | 05:44 PM
  #39
alex30327's Avatar
alex30327
Where can one find the colored 4 gauge Monster cable. I assume Home depot and the likes will not carry this.
Old Dec 11, 2002 | 03:37 AM
  #40
alphared's Avatar
alphared
where did you purchase the lugs from? Pepboys didn't have them (or anything else), but they did have a socket set for 3 bux
Also where did you get your crimper from and how much?
Thanks
