Slipping Clutch
Old Oct 31, 2004 | 08:04 AM
wick3d350Z's Avatar
wick3d350Z
Default Slipping Clutch
I was praticing launching my car last night. I turned VDC off. THe second time launching towards 4k rpms the clutch pedal sticks slowing down the car a little bit. This did not only happen once, but 2-3 times. This happened long ago at the track also. Now daily driving i dont see a problem. Just when i launch. Yes i did launch a few times without this problem. WHAT is going on for this to happen ever so often? Ive been thinking about replacing stock clutch and flywheel. Is this common?
Old Oct 31, 2004 | 08:27 AM
spdu4ia's Avatar
spdu4ia
yea ... i went through the stock clutch/flywheel in 10,000 miles. now at 20K and not a problem with my JIC/Stillen combo.
Old Oct 31, 2004 | 08:39 AM
wick3d350Z's Avatar
wick3d350Z
i am at 5k miles....at this rate..it will be 10k
Old Oct 31, 2004 | 01:22 PM
Dissolved's Avatar
Dissolved
Learn how to drive. I have 16k on my Z with lots of track time on the stock clutch. Doesnt slip at all.
Old Oct 31, 2004 | 01:42 PM
wick3d350Z's Avatar
wick3d350Z
i know how to drive :-p clutch shouldnt slip like it does
Old Oct 31, 2004 | 02:30 PM
Dissolved's Avatar
Dissolved
Here's a hint: dont launch your Z at 4000rpms and the clutch wont wear out prematurely. There are people on this board in the 12s that launch under 3k. You'll wear out an aftermarket just as fast with your type of driving.
Old Oct 31, 2004 | 06:26 PM
PhoenixINX's Avatar
PhoenixINX
43k on my clutch when I pulled it out...
I had PLENTY of clutch left.
Old Nov 1, 2004 | 10:03 AM
j's350z's Avatar
j's350z
I had about 40,000 also on my stock b4 swapping it and it was fine on the road but was slipping it at the track.. I had about 25+ trips down the 1/4 b4 any major problems.... I think the stock clutch is pretty decent...
Old Nov 1, 2004 | 01:39 PM
wick3d350Z's Avatar
wick3d350Z
i was launching at 3k. My toyos are pratically new. Maybe they are sticking to good? slipping didnt occur until 4.5k. I need a few great launchs. I am goint to the track thursday night to test it out again....any good pointers?
Old Nov 1, 2004 | 02:56 PM
PhoenixINX's Avatar
PhoenixINX
Slip at 3500rpm... It'll give you a nice launch!
Old Nov 1, 2004 | 03:39 PM
Dissolved's Avatar
Dissolved
Yes, sticky tires can cause a slipping clutch but I've only experienced it with DRs. If your clutch is really slipping, it will show when you accelerate from a roll. Get the car in 5th gear and floor it. See what happens.
If you're racing on a sticky track and warm weather, launch around 3k or 3500 like Phoenix said. If it's cold out and track is not sticky, adjust your launch. 2000, 2500 etc.
Oh, and drive AROUND the water box
loudtoyz
Apr 6, 2023 04:52 AM
sherm
Apr 11, 2020 05:21 PM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
