Knowing what you know now, what performance mod would you do first and why?
Old Nov 2, 2004 | 10:52 AM
Diesel350's Avatar
Diesel350
Default Knowing what you know now, what performance mod would you do first and why?
Old Nov 2, 2004 | 11:09 AM
L.A. Roadster's Avatar
L.A. Roadster
Clutch & flywheel. I love my JWT combo, but if I was doing it over again, I might want to try the Tilton.
Old Nov 2, 2004 | 11:19 AM
seanrulz's Avatar
seanrulz
IMO, Intake and Exhaust. They are relatively inexpensive, and quite noticeable gains with nice sounds will give you a good start.
Old Nov 2, 2004 | 12:24 PM
VandyZ's Avatar
VandyZ
Plenum, Flywheel, cats, headers/exhaust/ecu
I like the results I got out of my stock car with just the plenum the best. Flywheel was a very fun addition for feel and driving enjoyment (unless it is the tilton :P). Cats seem to help the car the most in the exhaust side if everything else is kept stock. In order to get full benefit out of all the mods you must continue with Headers/exhaust/ecu but because of the prices they fall behind the others. Really all are necessary mods if you want to have any success in modding the car. This is just the way I see it
By the way I went this order myself: Plenum, Headers/Cats, ECU, ECU, ECU, ECU, Exhaust, ECU, Flywheel, Y pipe
Yes the ECU was trial and error.
Old Nov 2, 2004 | 12:40 PM
ProfessorKan's Avatar
ProfessorKan
I/H/E then Suspension/Wheels then ICE and dressup. In that order
Old Nov 3, 2004 | 03:33 PM
QuantumZ's Avatar
QuantumZ
My personal first mod on my Z was the Greddy kit.
The exhuast makes for a very fun car, though.
Mark
www.Quantum-Racing.com
Home of the Dynapack Dyno
Old Nov 3, 2004 | 03:35 PM
zillinois's Avatar
zillinois
3.9 Ring & Pinion and Cats or Crawford headers.
Old Nov 3, 2004 | 03:37 PM
arizzee's Avatar
arizzee
agree, with preference towards cats over headers.
Old Nov 3, 2004 | 06:18 PM
zzzya's Avatar
zzzya
1. I would do the plenum first for a couple reasons:
a. It helps the car to continue pulling until redline, whereas stock the car really starts to drag in the upper rpms.
b. The plenum has been shown time and time again to help resolve air/fuel issues with the front cylinders. To me this mod should be done by Nissan and it sounds like they are working on this issue for newer models.
2. The second mod I would do is Crawford Headers. Why, well there has been a lot done to show that our stock exhaust manifolds are a real bottleneck that simply do not allow proper flow of exhaust fumes out of the cylinders, especially with the stock cams. The Crawford headers really help in this area more than anything else on the market. Changing the rest of the exhaust does not help with this since the stock manifolds are the biggest issue. Once the stock manifolds are replaced with really good headers, then other exhaust mods will add the finishing touch. Even with the stock cats and exhaust you will notice big improvements with just the Crawford Plenum and Headers.
Old Nov 3, 2004 | 06:41 PM
PhoenixINX's Avatar
PhoenixINX
Old Nov 3, 2004 | 06:53 PM
zYouLater's Avatar
zYouLater
Real simple: Get the air in and get the air out.
Cold Air Intake and TRUE Dual Exhaust.
Attached Thumbnails Knowing what you know now, what performance mod would you do first and why?-z-aluminum-vent-covers-0081.jpg
Old Nov 4, 2004 | 09:04 AM
ttsupra94's Avatar
ttsupra94
Exhaust. First mod i did was injen CAI and a grounding kit. They look nice but i try not to drive in the rain and its probably an extra worry and it doesn't add too much performance, although it does look good. I might have gotten one eventually, but i think an exhaust would have been a better first mod
Old Nov 4, 2004 | 09:23 AM
TheBigShow's Avatar
TheBigShow
flywheel/clutch or gears. i don't have either, so i am just guessin, since the mods in my sig haven't really knocked my socks off.
Old Nov 4, 2004 | 09:32 AM
Diesel350's Avatar
Diesel350
Wow we have some vastly different opinions. Some people say get the intake first and some say no way go with exhaust first and others say flywheel clutch.
Old Nov 4, 2004 | 05:16 PM
zzzya's Avatar
zzzya
I have nearly all of the N/A mods available and I have tried many combos with my stock parts. The flywheel/clutch and the final drive will make a bigger impact than pretty much any single N/A mod out there. They will help you utilize the power that the engine is currently making by moving the car through the rpms much faster. However, if you want more power output on the Dyno, the plenum and headers will do more than any of the other N/A mods. This car has a decent intake and exhaust from the factory and only until you start adding some serious engine mods will you start to benefit from HF Cats, a better exhaust and a CAI. Don't get me wrong, you will possibly see some difference with any of these mods, but they will come no where near the results of the plenum/headers combo. After the plenum and headers you can start to open the other things up and then add cams and have the ECU reflashed. Then you are talking serious improvements, but a lot of dough.
Old Nov 4, 2004 | 05:29 PM
alininger2001's Avatar
alininger2001
This could be a good start. Crawford cats, Borla TD, Headers, and a JWT Popcharger.
Old Nov 4, 2004 | 05:57 PM
StarcraftBW's Avatar
StarcraftBW
Plenum, Highflow CATS, and ECU
Old Nov 4, 2004 | 07:11 PM
Nano's Avatar
Nano
shocks springs sways.......... then brakes
Old Nov 4, 2004 | 10:28 PM
Barzten1's Avatar
Barzten1
Gotta have wheels but for performance I would say exhaust , CAI & pullies!
Old Nov 4, 2004 | 10:42 PM
fdao's Avatar
fdao
I agree with you completely! If I were to do it over again, I would do the final drive and clutch/flywheel combo as my first mods.
davidm350
Oct 31, 2015 02:28 PM
Ace2347
Sep 22, 2015 03:12 AM
EnjukuRacing
Sep 18, 2015 07:57 AM
