NISMO/KAAZ LSD Question
Old Nov 6, 2004 | 05:38 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
yep...typed too fast
NISMO, as far as I am aware = Cusco MZ
Cusco RS adds springs to the clutch pack design, making for nice smooth engagement...one of the best mods we did to my car so far!
Old Nov 6, 2004 | 07:02 PM
daveh's Avatar
daveh
The RS sounds like a good unit. Does anyone know who makes the nismo?
Are you saying that the nismo is made by cusco (MZ) or is it just similar. Nissan has to outsource it to someone..
Old Nov 8, 2004 | 05:22 PM
saint01's Avatar
saint01
any idea how much the dealer is should be charging me for an install of the KAAZ LSD? I just bought one and amy looking to get it installed
Old Nov 8, 2004 | 06:01 PM
Z1 Performance
Former Sponsor
install for the rear diff into an LSD equipped car should be around $200-$250 tops
Yes, from everything I have found so far, the NISMO diff = Cusco MZ.
Old Nov 8, 2004 | 07:31 PM
uro279's Avatar
uro279
Can you explain the difference between Cusco MZ and RS?
You stated that the MZ is more 'hard core' compared to the spring loaded RS-what do you mean by this? Does the MZ tolerate more stress? What are the other differences?
Thanks.
Old Nov 12, 2004 | 11:04 AM
zlex's Avatar
zlex
After hearing people talk on the forums about clutch type lsd vs. gear type lsd i think the cusco rs is a good choice. since it doesnt come with all the components for install, can anyone list the parts that the cusco rs system would need and price ?
Old Nov 12, 2004 | 07:13 PM
Z1 Performance
Former Sponsor
do a quick search..g35sedan has posted the part numbers a few times before.
Old Nov 12, 2004 | 09:38 PM
Gsedan35's Avatar
Gsedan35
I keep a lot of different word files handy, here's the info he needs.
Those parts are(I'll list the retail price that you'd normally have to pay if purchased seperately, if you can get them for less then retail, all the better),
new stub axles $148 each, part numbers 38220-AR011 and 38220-AR010.
2 Oil Seals $6.50 each ment for a stock limited slip equipped diff part number 38342-P9010
2 Differential Bearing* assemblies $48.00 each, also ment for a limited slip equipped diff part number 38440-0C000
*Word is, you may be able to reuse your original bearings, but given the amount of metal shavings that can come out of a oem diff even with low mileage, might be a sensible investment, your call.
Old Nov 12, 2006 | 12:01 PM
bofa's Avatar
bofa
Sorry to dig this one up from the grave, but doing a little research...
It sounds like there's not much of a price diff between getting the Kaaz and buying the other parts and getting the Quaife that has everything you need... right? (Coming from a 350Z Base owner)
Now that the Quaife has been out for a while, opinions on Kaaz vs Quaife?
Old Nov 12, 2006 | 03:09 PM
betamotorsports's Avatar
betamotorsports
Being around racing circles for the last 10 years, the general opinion is that in high horsepower, rear-wheel drive cars (above 300hp) Quaifes dont work well, they cause the car to go from understeer to oversteer and back again when your cornering. Also the cars were getting massive inside wheel spin. Dont get me wrong, Quaife makes a great product, just doesnt work well for a high HP rearwheel drive application, it was originally designed for Front Wheel Drive cars and works really well in those applications.
Many racers have problems with Quaife and other gear type differentials because they require a different chassis setup then a clutch type LSD. Having run a Nissan Competition LSD and a Quaife LSD in my racing 240Z (320 hp, 2,100 lbs, 23 x 10 x 16 slicks or 275/45/-16 Hoosiers) I can say that the Quaife diff took 1% off my lap times, which at WSIR is 3 seconds.
I did have to move anti-roll forward on the car and increase rear shock low speed compression and reduce low speed rebound. Quaife and Torsen diffs cannot have an inside rear wheel lift or the unit goes open. It also takes a different driving style with the driver having to trail brake to get the car rotating quicker so power can be applied sooner.
Unless a team and driver is willing to invest the development time to adapt the chassis to the diff, I can completely understand how they would feel a Quaife or a Torsen unit would suck. This kind of swap is not something to be done mid-season.
Old Nov 12, 2006 | 04:47 PM
bofa's Avatar
bofa
So for street driving, you would suggest a clutch style? What about noise (for street driving)?
Old Nov 12, 2006 | 07:38 PM
g356gear's Avatar
g356gear
I had the KAAZ in my car and it worked great performance wise but drove me crazy for strret driving. Going around corners at slow speeds it popped and banged like mad. People standing on the corner of the street looked at me like my car was broken!! I switched out to a VLSD for daily driving. If I was going to do it again I would go Quaife hands down. Cheers.
Old Nov 13, 2006 | 07:09 AM
betamotorsports
For street driving I woudl recommend the factory VLSD. IMHO, the $1400 (plus installation) a Quaife costs doesn't provide enough of an improvement over the factory part on a street driven car.
Old Nov 13, 2006 | 06:25 PM
bofa's Avatar
bofa
Hmm... anyone want to sell their VLSD?
Old Nov 13, 2006 | 06:47 PM
bofa's Avatar
bofa
Alright.. so now I'm searching for VLSDs for sale (whole pumpkin)...
What the heck am I looking for? 3.3? 3.5? 3.9?
I have a 2006 M/T Base... current'y N/A with the possibility of going Supercharged depending on how this oil-burning issue plays out....
Old Nov 14, 2006 | 04:33 AM
gringott's Avatar
gringott
What you should do is find someone who wants to do the quaife and needs the base diff, and has the VSLD, do a swap with them. Personally, I recommend you go with the stock 3.5 final drive.
Old Nov 14, 2006 | 05:52 PM
bofa's Avatar
bofa
Why the 3.5 FD over the other two?
Old Nov 15, 2006 | 03:11 AM
  #38
gringott's Avatar
gringott
Since you are NA, 3.3 would be too low IMO.
And you might go FI, so 3.9 would be too high, if you were for sure staying NA then it might be right for you - lots of dissusion about this here - do a search - again IMO. Although I think some with SC are running the 3.9, again, do a search.
3.5 would be just right.
I considered swapping to a 3.3 with my TT setup, but after reading the various experiences on here, decided to stay with the 3.5.
Old Nov 15, 2006 | 02:58 PM
  #39
bofa's Avatar
bofa
Thanks for the info.. I'll keep plowing through the old stuff.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
