does the future look good for the guys who wanna go NA all the way?
Old Nov 13, 2004 | 03:26 PM
zillinois's Avatar
zillinois
Originally posted by axxizzer
...dunno about teh 3.9 and the tilton, sounds like it'd hit its peak REALLY quickly
And might have a drastically lower top-end
and forgot to add
NISMO cams to that list
Ditto on the cams.
I've got the 3.9 and the Tilton and its an incredible combo from a roll. I'm heading out to the track tomorrow to see if I can actually launch on street tires.
Old Nov 13, 2004 | 07:51 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Originally posted by zlex
If you install turbo there are issues like lag while NA you get a smoother powerband etc. There are lots of reasons.
You're not going to get any lag with a stock compression VQ35 with turbos vs. an N/A VQ35.
The reason some turbo cars have lag is because they have lower compression...so unless you build the motor will low comp pistons...you will have the same power off boost as an N/A 350Z.
Old Nov 15, 2004 | 11:14 AM
kzshin's Avatar
kzshin
plus, if you have correct size turbo, with ball bearing center. Most likely you won't feel the lag.
Old Nov 15, 2004 | 01:46 PM
imcool's Avatar
imcool
Originally posted by turbo-maxima
The NSX engine is extremely reliable. They don't even stock NSX parts here in america, everything must be ordered from Japan. I think the S2000 with a V6 would be a equal replacement for the NSX except for body styling. S2000 is like half the size. They have gotten 450+ N/A horsepower from NSx engines without increasing the compression ratio that much. Still able to run on street gas but they have higher octane gas in japan. I think 450 whp is possiable without a stroker kit. I would say using the Vq30 crank and rods making it easier to to rev into the 9000+ range. thats the only way too make big power. And Individual throttle bodies must have to be used. 9000 rpm with close gears would be incrediable.
The nsx is a legend motor isnt it?
Old Nov 15, 2004 | 02:30 PM
PhoenixINX's Avatar
PhoenixINX
Yes and no...
Similar design, except the Legend was a SOHC... whereas the NSX was a DOHC.
Jambo016
Sep 16, 2016 01:08 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
kyin
Oct 15, 2015 05:54 AM
35reilly
Sep 28, 2015 07:42 AM
