Underdrive Crank pulley question
Old Nov 20, 2004 | 08:34 PM
MustGoFastR's Avatar
MustGoFastR
Originally posted by Z1 Performance
I have logged nearly 50 hours on my car with the pulley on and off...no change in timing whatsoever
I have witnessed Z's with very few mods (fewest was intake and exhaust, period), run mid 13's at the strip...insanely quick compared to what most NA modded cars (ecu, test pipes, etc) run. Different cars, different build dates, etc - sometimes people just get exceptionally strong runners!
The sensors on most cars are very sensitive, which is how they should be for a street driven car on pump gas. If the car is tuned properly, there is absolutely NO reason that the knock sensor should be picking anything up other than actual knock.
So what do you think about my situation? No dissassebly or messing with tuning here. You think the guy with the stock vehicle just has a strong engine? Hard to imagine that much variance for a stock car to beat my intake/plenum/pulley combo consistently by .2 and only pull on me in the last 1/16 mile in 3rd.
What's the cheapest data logger that'll do what I need it to? Workin' on a budget here.
Old Nov 20, 2004 | 08:40 PM
Zmego1985's Avatar
Zmego1985
I would put the factory pulley on and test it out again.
Thanks Glen
Old Nov 20, 2004 | 08:43 PM
Zmego1985's Avatar
Zmego1985
I have a dent on my pulley from taking off so many times. This could not harm anything can it? I dented it by binding the pulley up so i could get it off.
Im not sure what the hells causing the knock sensor to go off. I have way to many upgrades now that i got myself in a hole.
Thanks Glen
Old Nov 20, 2004 | 08:52 PM
MustGoFastR
Thanks Glen
I was afraid you were going to say that. Not exactly something I'm looking foreward to: not quite as easy a job on an AT.
Still thnk I'll try to get my tech to make a few runs with me and watch it on the ConsultII. Not sure what it'll tell him, though. Will it or any data logger say if knock is being detected, or does it just display what the timing is at any given time? Wouldn't you need to know, then, what the timing curve SHOULD look like to be able to tell if anything's amiss? Anybody have that info? I have no idea what the timing curve should look like.
Old Nov 20, 2004 | 09:22 PM
Zmego1985's Avatar
Zmego1985
Look up the old threads on pulleys.
Thanks Glen
Old Nov 20, 2004 | 09:25 PM
Zmego1985's Avatar
Zmego1985
I have my rev limiter highered and i have the unorthordox pulley on. Im nervous now that it caused crank bearing problems and thats why i have a timing loss because the knock sensor feels the vibrations. Look up old threads on pulley problems one person had timing issues.
I noticed the higher i reved my car the more timing was being pulled on the dyno. If that pulley does vibrate it sure would vibrate the most at high rpms. I think im going to go back to stock for my own thoughts.
Old Nov 21, 2004 | 06:33 AM
MustGoFastR
I'm not referring to vibration from the pulley. I have Blackstone labs oil reports showing I have no abnormal wear that would be caused by an unbalanced pulley. I'm referring to noise that is otherwise dampened by the rubber ring (not a harmonic balancer) in the stock pulley. I do not lose power at all in 1st or second, but only under load as rpms rise in 3rd. I'm thinking that there may be noise from the pulley that is at just the right frequency at that time to be picked up by the knock sensors.
IF that's the case, still unsure if it's worth going back to stock b/c I never drive under those conditions on the street and the pulley DOES have it's gains.
Old Nov 21, 2004 | 06:45 AM
MustGoFastR
Found a couple references, but no thread discussing it in detail. Little help?
Old Nov 21, 2004 | 07:18 AM
Machupo's Avatar
Machupo
just curious if the AT has different shift points for different gears at WOT... if it were a problem with your pulley (and the shift points were the same, or 1/2 were higher than 3rd) then you would experience this in each gear (as the pulley goes through the whole rpm range in each gear)... well, if you have verified that you are indeed getting knock (physically, by inspecting the spark plugs IIRC, at least that's how it was in my old volvo) i'm officially stumped
Fixxxercask
Nov 9, 2015 11:10 AM
