Grounding Wires Worth It?
Old Nov 20, 2004 | 07:50 AM
painter55's Avatar
painter55
Default Grounding Wires Worth It?
Got the '03 Touring Z a month ago. Now that I learned how to drive the little devil, I am looking at some performance enhancements, starting with the cheapest and most effective. Grounding wire sets? Worth it? Your real-world experience and advice are welcome! And what else short of a turbo?
Thanks,
Bobby in Chicago
Old Nov 20, 2004 | 09:42 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Default Re: Grounding Wires Worth It?
Thanks,
Bobby in Chicago
From what I have heard, ground wires don't do much, but I could be wrong.
Old Nov 20, 2004 | 09:47 AM
Monsta's Avatar
Monsta
I didnt feel anything for power but the kit did smooth out the idle. It revs smoother.
Old Nov 20, 2004 | 09:48 AM
DavesZ#3's Avatar
DavesZ#3
Looks cool.
Old Nov 20, 2004 | 12:20 PM
OP Z's Avatar
OP Z
Go for the JWT pop charger Bobby. Most would agree that this is the best bang for the buck mod. $110. No doubt about it.
Old Nov 20, 2004 | 01:24 PM
johnsZ's Avatar
johnsZ
Looks like the ground wire thing is resurrecting.
I posted about this a long while back.
Using a milli-ohm meter (very sensitive ohmmeter), my ground measured a few milliohms. Adding the wires will reduce this resistance by perhaps one or two milliohms- that is, essentially no difference. The wire set looks cool, but does not do a thing for the ground other than potentially create a ground loop, which may affect other things, but not likely to be significant. The ground wires are a cool looking thing to add color under the hood, but seriously do not do anything that positively affects the motor or the ignition or the ECM (computer).
If you want to add some color- great, but don't expect the motor to jump up and add horsepower!
Add a K&N filter in the air intake, one step colder spark plug (the -6 instead of the standard -5) and add 2 or 3 gallons of 100 octane fuel to a tank (about 5 bucks per gallon)- this will allow the ignition to max out the advance without detonation- this is a performance kick that you can actually measure.
Have fun!
Old Nov 21, 2004 | 12:07 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Thanks,
Bobby in Chicago
I gave a Sun Auto Hyper Voltage System and Hyper Grounding system a shot and it surprisingly works. Idle is smoother, revs are cleaner, shifts are smoother, voltage is more consistent (odyssey battery), and things hooked up to electrical system have more power. My remote bottle opener for my nitrous bottle seems to now be turbocharged! More power? Butt dyno cannot tell.
350Z_Al
Oct 29, 2020 07:44 PM
ablaine
Nov 29, 2016 10:13 AM
nanotech
Oct 2, 2015 05:02 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
