DIY plenum porting
Old May 12, 2006 | 09:04 AM
  #181
ACEMAN's Avatar
ACEMAN
Master
Originally Posted by bilinghm
I'm not sure that it will make any differece either. However...
It may provide extra voulme in a way completely different and more benficial than a spacer. The spacer provides headroom over the cramped spot above the two front runners. Shaving the two front runners does the exact same thing. Untapered spacers also multiply the effect of the slanted lid of the 350Z plenum. They provide more room over 1&2 where is is needed, and even more room over the other runners where it isn't actually required. We also know that too much headroom can upset the pressure balance, potentially altering the velocity of intake air and harming low end torque.
Opening up the bowls along with shaving the 1&2 port roofs might be a excellent compromise. More headroom for 1&2, and a volume incease that effects all runners equally.
I'm beginning to believe that a properly modifed lower plenum will make spacers obsolete. I think many of the dyno results that we are seeing on the Mrev+ are providing the evidence.
Have I got the solution? Who knows?
I say give it a try
I will have another plenum to mess around with once i put this one on my buddies car. I know its going to make more power than stock, just not sure how much. So with the second plenum i can take from what i have learned and hopefully improve apon it.
Later
Aceman
Old May 12, 2006 | 10:05 AM
  #182
bilinghm's Avatar
bilinghm
Here is a photo of where I plan to mill out the bottom of the "bowl" area. Inside the dotted line.
Old May 12, 2006 | 10:07 AM
  #183
ACEMAN's Avatar
ACEMAN
Master
OVER 10 HOURS OF CYLINDER HEAD & INTAKE MANIFOLD SECRETS
http://racingsecrets.com/speedtalk_head_porting.shtml
INTAKE MANIFOLDS
Tell us about the different manifold designs, and the advantages/disadvantages of each.
Give racers advice on picking the right manifold.
How to design a manifold from scratch.
Manifold Porting: How do you decide size and shape? How do you do the modification? Let's look at each part of the intake and get your thoughts.
Carb Flange
Plenum
Dividers
Runner entrance (at plenum)
Runner roof
Runner floor
Runner walls
Runner exit (at gasket)
What are your thoughts on fuel distribution?
What are your favorite formulas relating to intake manifolds?
What are the latest trends in manifold design?
What are the latest trends in manifold porting and modification?
What are the biggest mistakes people make when it comes to manifolds?
Biggest discoveries you’ve made working on intake manifolds?
Looks like these CD's would be very helpfull, and they are only $99 and it comes with a Vinyl Carrying Case ( very cool )
Later
Aceman
Old May 12, 2006 | 10:20 AM
  #184
ACEMAN's Avatar
ACEMAN
Master
So your going to add more material underneith and then mill it out??
Old May 12, 2006 | 10:26 AM
  #185
bilinghm's Avatar
bilinghm
That is exactly correct.
Old May 12, 2006 | 12:56 PM
  #186
StarcraftBW's Avatar
StarcraftBW
^^very interested thought
Old May 12, 2006 | 04:38 PM
  #187
aleok's Avatar
aleok
great idea, be careful
Old May 16, 2006 | 10:48 AM
  #188
LaPuLaPu's Avatar
LaPuLaPu
bilinghm,
Any update or dynos?
Old May 16, 2006 | 11:39 AM
  #189
bilinghm's Avatar
bilinghm
Default Plenum corner
I have heard some comments and speculation that rounding off the corner shown in the photo would be a worthwhile modification. I have my personal doubts. There are two of these corners, one "corner" on the the left front by runner 1 and on the right rear next to runner 6. These little corners were very deliberately designed into this casting and NOT a mistake or overlooked opportunity. They are obviously designed to create a low pressure area below the lip and probably induce a swirl or vortex as the air cascades off the edge. The face of the corner below the lip is even slightly concave, further strenghtening my belief that this is a purpose designed arodynamic feature, not a mistake. I think the mistake would be to grind this off.
Polishing this area would probably be O.K. but I believe the original contours should be maintained unless somebody has either flow bench information or computer simulations that show an improvement with this area removed.
Old May 16, 2006 | 11:48 AM
  #190
ACEMAN's Avatar
ACEMAN
Master
LOL woooooops, well i guess we will see if it was a mistake to grind that down some
Later
Aceman
Old May 16, 2006 | 11:49 AM
  #191
bilinghm's Avatar
bilinghm
Another photo of the corner.
Old May 16, 2006 | 12:16 PM
  #192
ACEMAN's Avatar
ACEMAN
Master
I will see if i cant get some pics up tonight, when i get home from work.
Later
Aceman
Old May 16, 2006 | 04:02 PM
  #193
ACEMAN's Avatar
ACEMAN
Master
Here are a few pics, still need to finish the polishing. But this is the basic port design i will be dynoing on a bone stock car. So i guess we will see how well this works out for me
Later
Aceman
Attached Thumbnails DIY plenum porting-dsc01137.jpg   DIY plenum porting-dsc01136.jpg   DIY plenum porting-dsc01138.jpg
Old May 16, 2006 | 04:15 PM
  #194
ACEMAN's Avatar
ACEMAN
Master
Few more pics
Hope to have it all finished later this week.
Attached Thumbnails DIY plenum porting-dsc01146.jpg   DIY plenum porting-dsc01151.jpg   DIY plenum porting-dsc01152.jpg   DIY plenum porting-dsc01153.jpg
Old May 16, 2006 | 05:01 PM
  #195
aleok's Avatar
aleok
wow looks good, you really opened those up.
Old May 16, 2006 | 09:26 PM
  #196
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
aceman, that is either going to be really good, or really crappy. Looking forward to results either way.
Old May 16, 2006 | 11:11 PM
  #197
OCG35Coupe's Avatar
OCG35Coupe
Here is my bowl just polished..
Are there any downsides to this??
Old May 16, 2006 | 11:16 PM
  #198
taurran's Avatar
taurran
Did you do that yourself?
Old May 16, 2006 | 11:22 PM
  #199
OCG35Coupe's Avatar
OCG35Coupe
No, took it to a polishing shop..Told them to add it to my dads next bill
Old May 17, 2006 | 12:10 AM
  #200
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
uh.. your dad's next bill? that's cute... hope you're kidding..
I don't really see a downside as it would reduce air friction, I'm assuming
