DIY plenum porting
Old Mar 7, 2011 | 01:06 PM
  #561
pfregeolle's Avatar
pfregeolle
Originally Posted by bikinilust
AWESOME DISCOVERY: an amazing way to clean the plenums of dirt and oil is to use AIRPLANE PAINT STRIPPER. Spray or brush it on, wait a minute or two, and rinse. No scrubbing at all. Comes out looking better than new.
I've used various grades or degreasers, detergents, brake cleaner, gasoline, acetone, paint thinner, engine degreaser, even steam clean. AIRPLANE PAINT STRIPPER hands down is the easiest, fastest, product to use with the best results possible
Just don't get it on anything else! Hahah
I will try this when I clean up my plenum pre-installation
Old Mar 8, 2011 | 12:16 AM
  #562
Mcutali's Avatar
Mcutali
Default re
This isn't that big of a deal with an angle grinder and sanding discs. Just use several grits, don't go crazy, and a little trick to make the disc last longer: sand a stick of wax for a quick second, just enough to get a thin layer of wax on the disc. This will make the discs last longer. Little trick the pros use.
never said it was a big deal. maybe took 4 hours total. better than paying a bs shop 200+$$ hard earned money. oh having a 20 gal compressor doesnt help, try 80gallons.
Old Mar 8, 2011 | 07:56 PM
  #563
pfregeolle's Avatar
pfregeolle
Alright guys! Finished my lower runners tonight! Took some pictures with my cell phone; First pic is of the heads' side, second pic is of the lower plenum side; third pic is a close-up of one of the runners to the head; and fourth pic is a close-up of one of the runners from the lower plenum.
Very shiny! But trust me, it's not super smooth. I didn't smooth it out too much, just polished with some aluminum polish and I will clean the whole thing off with some of that airplane paint stripper before I paint it!
Attached Thumbnails DIY plenum porting-img00169-20110308-2318.jpg   DIY plenum porting-img00172-20110308-2319.jpg   DIY plenum porting-img00170-20110308-2319.jpg   DIY plenum porting-img00171-20110308-2319.jpg
Old Apr 29, 2011 | 04:49 PM
  #564
pfregeolle's Avatar
pfregeolle
Some pictures to keep folks entertained:
I'm about to tape off the lower plenum right now to prepare for wrinkle coat on the exterior of that as well. I will post more pics when I get it painted, and when it's installed / comparison to the old one that's on the car now.
Old Apr 30, 2011 | 05:41 AM
  #565
SexyRob's Avatar
SexyRob
looks good, very smooth... I dunno if it makes a difference but I left mine slightly rough because I heard if its too smooth it actually does worse since there isn't enough turbulence to mix the air and fuel before it gets into the cylinder.
Old Apr 30, 2011 | 06:08 AM
  #566
0jiggy0's Avatar
0jiggy0
Theres 2 sides that will argue for days on that.
Old Apr 30, 2011 | 06:12 AM
  #567
pfregeolle's Avatar
pfregeolle
I heard the same as well Rob. But I've also read that it really only applies to carbureted engines, and only in parts of the engine where the fuel mixes with incoming air. So I'm really hoping that it being too smooth doesn't affect it in a bad way. I just sprayed the lower plenum exterior last night, so that's drying all day today and I will be installing everything tomorrow. I also just installed my single exit exhaust Wednesday, so I hope that combined with the exhaust, I really feel some improvements tomorrow.
Old Apr 30, 2011 | 06:16 AM
  #568
0jiggy0's Avatar
0jiggy0
If it at least sounds better, post up a vid.
Old Apr 30, 2011 | 06:21 AM
  #569
pfregeolle's Avatar
pfregeolle
Hahaha yeah exactly, that's why I figured I'd just go for it and smooth it out. I only went up to 220 grit.
Either way, it should sound freaking sick, especially because I'm doing the upper plenum (which is also cast flashed and polished) and the 3/8" spacer. I'm really excited to get it all on.
Old Apr 30, 2011 | 10:47 AM
  #570
Voboy's Avatar
Voboy
^- your work looks very, very good... I did the same thing to the lower plenum minus the runners below... didn't have the necessary tools to get in those tight spaces :/ I did however smoothen it out as much as I could by hand sanding but not extensively... oh well maybe every little bit can help
any thoughts on dynoing?
Old Apr 30, 2011 | 03:42 PM
  #571
bikinilust's Avatar
bikinilust
Looks awesome.
what tools and accesories did u use?
and roughly how much time put in?
Pix of items would be appreciated
Old Apr 30, 2011 | 04:11 PM
  #572
bikinilust's Avatar
bikinilust
Pfregeolle would have to do a before any after dyno one after the other within a relatively short period of time so that all parameters are roughly the same.
Pfregeolle would more than likely have to pay for 2 sets of dynos as well
Im sure all of us would be interested in those numbers though
Old May 2, 2011 | 05:53 AM
  #573
pfregeolle's Avatar
pfregeolle
I got a lot of interest and people asking for me to dyno before and after, but I just didn't feel like taking the time to go up to a shop, have it dyno'ed. Then sit there in the parking lot and install everything then re-dyno it hahaha But I'd love to know how much it makes now. It's been kind of raining lately in my area so it's hard to really get on it. But it does feel like it's pulling harder, especially in 3rd. I think I might disconnect the negative terminal and reset the ECU just so it can re-learn itself with the whole new setup.
Looks awesome.
Tools I used included a sander and some REALLY low grit paper to take the front two runners down about 6mm. A dremel tool with some 80 and 120 grit flap sander bits for getting into the runners. And some aluminum oxide sandpaper from 60 grit up to 220 grit, and a little of 1000 grit in a few spots to really smooth it out. Honestly a majority of it was done by hand, which REALLY SUCKS! I probably would never do this again. If I did, I might do the Intake Manifold (lower runners) again because that was the easiest part of the whole process. And maybe try and sell them or something. I put way too much time into all this hahaha But I guess it's worth it. Overall this has been a year-long project. But you have to remember I flashed and polished both the upper and lower plenums and the intake manifold. So probably a good 60 hours or something retarded like that. I just installed everything yesterday, I have a few shotty cell phone pix from my Facebook, but I also took photos during the install and I will post up the good ones tonight. In the meantime here are the cell phone photos:
Attached Thumbnails DIY plenum porting-210132_594749282549_203804210_33172561_5803882_o.jpg   DIY plenum porting-220843_594765779489_203804210_33173022_461054_o.jpg   DIY plenum porting-210502_594775779449_203804210_33173357_7814004_o.jpg   DIY plenum porting-200835_594786542879_203804210_33173650_6901766_o.jpg
Old May 2, 2011 | 08:22 AM
  #574
bikinilust's Avatar
bikinilust
Looks sweet.
When u say FLASH AND POLISH, what is flash?
Old May 2, 2011 | 08:23 AM
  #575
bikinilust's Avatar
bikinilust
Old May 2, 2011 | 08:43 AM
  #576
pfregeolle's Avatar
pfregeolle
I was just about to post a link for you haha But did you find out what the casting flash was?? If not, refer here:
http://www.aircooledtech.com/casting_flash/
Basically just getting rid of all the excess aluminum inside the runners from when the plenums and manifolds are produced. Less air flow restriction.
Old May 2, 2011 | 08:49 AM
  #577
bikinilust's Avatar
bikinilust
ahhhhh gotcha.
I know what you are talking about now. Just wasnt familiar with the term FLASH
Old May 2, 2011 | 01:48 PM
  #578
tollboothwilley's Avatar
tollboothwilley
The mrev has 5mm cut off the top of the front two runners
where is this number coming from? I've heard differently.
Old May 2, 2011 | 04:08 PM
  #579
bikinilust's Avatar
bikinilust
I measured the difference between the MREV2 and a non revup lower plenum.
I measured with a measuring caliper.
Old May 2, 2011 | 04:53 PM
  #580
LoSt's Avatar
LoSt
I picked up a non revup lower plenum to port out a bit. How much should I take down the front runner? Two posts up says the mrev is shaved down 5mm, is that the 'best' or optimum amount?
Work from pfregeolle above looks awesome. Might have to buy a dremel now, was gonna tackle this with a grinder, files, and sandpaper.
