Oil Cooler Install With Pictures
Old Feb 29, 2008 | 07:52 AM
  #41
MUZZY's Avatar
MUZZY
I tested some different arrengments but found that the power enterprise oil pan with the buttom plastic shroud removed worked best for me. my max temps are at 200 degree.
Old Feb 29, 2008 | 08:41 AM
  #42
Fleet Z's Avatar
Fleet Z
Nice install.....Clean and neat.....Stainless braided hose would be sexier.
Old Feb 29, 2008 | 01:39 PM
  #43
jining's Avatar
jining
im speaking of the fittings required to connect the 90 degree to the oil cooler itself. I dont believe those were included in the list
Old Mar 1, 2008 | 03:27 AM
  #44
RBALDINELLII's Avatar
RBALDINELLII
They are on the list, just not in the picture. #5 on the list of stuff you need mentions 4 are needed. I'm not sure why I didn't put them in the picture. My bad.
Old Mar 2, 2008 | 01:00 PM
  #45
jining's Avatar
jining
Wow so it works great!! After boosting pretty hard my temps only hit 170 max!!!! Used to hit 210 or more!!
Old Mar 3, 2008 | 01:55 PM
  #46
zman2's Avatar
zman2
Default Pics
Any photos of your install?
Old Mar 4, 2008 | 10:44 AM
  #47
turtle1678's Avatar
turtle1678
When installing the sandwich plate did you use tape on the threads of extender to the stock oil filter hold threads, does that make sense
to make sure its not loose, not the filter but the oh you know what I mean
Old Mar 4, 2008 | 10:48 AM
  #48
Zivman's Avatar
Zivman
no, do not use tape there. tighten it down with a wrench and you will be fine
Old Mar 4, 2008 | 12:40 PM
  #49
jining's Avatar
jining
Yea I figured that so I just tightened it, no tape.
Old Mar 4, 2008 | 03:47 PM
  #50
turtle1678's Avatar
turtle1678
which way does the side with the gasket go towards?? I have a feeling its in not on the side with the oil filter
Old Mar 4, 2008 | 04:26 PM
  #51
rrmedicx's Avatar
rrmedicx
Ding! You are correct sir!
Old Mar 4, 2008 | 08:39 PM
  #52
Slow_CPV35's Avatar
Slow_CPV35
Just thought i'd chime in since i don't see burb ports on any of these coolers. Did the people who have installed these take the time to run the motor with the coolers in an fashion where the ports were right side up? If not, you've probally trapped some air in the top of the core, and are thus screwwing yourself out of some added efficiency.
Old Mar 11, 2008 | 05:07 AM
  #53
RBALDINELLII
I understand what you are thinking. But I actually took the idea of mounting it this way after looking at some of my motorcycles. Ie... Triumph speed triple. They were all mounted what seems like upside down. I figured if it was good enough for such a small volume engine, it probably wouldn't be to bad in this application. You could be right, but the cooler seems to work extremely well.
Old Mar 11, 2008 | 05:19 AM
  #54
rrmedicx's Avatar
rrmedicx
Just curious if you think it would help to run the car first with the cooler port side up until oil has a chance to fill the cooler, then once that happens and the air is most certainly out, to then orient the cooler the way you want and secure it...to the bumper.
What device are you thinking to use to "burp" the system and purge the air out?
Old Mar 12, 2008 | 01:36 PM
  #55
RBALDINELLII
I'm sure you could, but I didn't find it to be necessary. Sure won't hurt anything to do it the way you are talking about though,
Old Mar 17, 2008 | 02:14 PM
  #56
turtle1678's Avatar
turtle1678
how much extra oil do you add to the car??
Old Mar 17, 2008 | 03:32 PM
  #57
jining's Avatar
jining
i added 1/2 quart, so now with my APS oilpan spacer, I add 6 quarts per oil change. Im actually curious how much oil sits in the lines and the oil cooler when I drain the oil... any input?
Old Mar 17, 2008 | 06:52 PM
  #58
turtle1678's Avatar
turtle1678
cool thanks
Old Apr 20, 2008 | 06:49 AM
  #59
iconZ33's Avatar
iconZ33
Just bought all the things on the list should be doing this by end of the week...
Great Write up
Old Apr 20, 2008 | 08:53 AM
  #60
TTRANK's Avatar
TTRANK
Great thread. Not that we built my motor I'm going to get a cooler too. This is very helpful!
