Cusco RS and 3.9FD install
Old Aug 16, 2007 | 08:14 AM
  #41
DustinZ33's Avatar
DustinZ33
This is a great write up on lsd and final drive install. I wanted to bump this to the top so others who have questions can see this.
MODS- maybe you can put this in the DIY section so we can find it easier for future reference.
Old Aug 16, 2007 | 02:41 PM
  #42
edwin350z's Avatar
edwin350z
great write up indeed! i am getting my 3.9 installed as i write this. the shop however didnt have the correct shimes in stock so it wont be done til tomorrow. i spoke to my installer and he said it was a breez so far... i will get you guys more info tomorrow afternoon
Old Aug 17, 2007 | 04:28 PM
  #43
edwin350z's Avatar
edwin350z
wow! i love this set up. thanks to alamo performance and their inexpensive and great work... i was told that first gear was going to be too short blah blh blah but it actually isnt too bad, i have a jwt fly and clutch set up so it was already short as it is. but i am mostly impressed with the end of 2nd and the rest of the gears!!! this thing is a beast now. all i need is to reflash my ecu and im good to go... has anyone heard any good stuff about technosquare?
Old Aug 19, 2007 | 08:21 PM
  #44
ZLadie2000's Avatar
ZLadie2000
how much did you spend on the install?? total...
Old Aug 24, 2007 | 12:36 PM
  #45
drivesolo's Avatar
drivesolo
This is an excellent thread. Thanks Bleunetizen.
Old Sep 9, 2007 | 11:05 AM
  #46
BillBeamon's Avatar
BillBeamon
Default Nice job!
Nicely done and well written. What did you do to get the speedometer and odo reading correctly? It's in the chip, right?
Thanks- Bill Beamon
Old Sep 10, 2007 | 07:20 PM
  #47
918 Z's Avatar
918 Z
nice write up, im having the nismo and 3.9 with nismo finned diff cover installed in about 2.5 weeks. cant wait
technosquare does very nice tuning. my friend just had his ecu flashed there and its been fun driving it.
Old Sep 11, 2007 | 11:55 AM
  #48
Fluid1's Avatar
Fluid1
then measured my favourite method of acceleration measure - 80-120km
it shortened 0.13 seconds off, down to 3.42 from 3.56. hopefully it will get better as the gears and lsd are worn in for smoother operations
One question about this. I thought that the 3.971 FD is supposed to help the lower end much more than the top end. GLad to see that the 80k-120k is helped as well.
Did you do any 0-62?
Old Sep 11, 2007 | 12:01 PM
  #49
bleunetizen's Avatar
bleunetizen
no i did not do any 0-62mph or 0-100kph comparison.. because shifting speed is a bit different everytime..
Old Sep 11, 2007 | 01:18 PM
  #50
ZTUPID's Avatar
ZTUPID
I want to try this one at home too... Little scary though. Will deff save alot of money. There are few shops that will even touch this job, and those who will, rape your a$$ on the price. I'm gonna read this writeup a few more times and see if I can build up the confidence.
Old Sep 11, 2007 | 01:24 PM
  #51
mw9's Avatar
mw9
Just ready to ask if anyone has tried it there self. Looks like a good project. Great job
Old Sep 11, 2007 | 01:26 PM
  #52
Jay'Z's Avatar
Jay'Z
I think ill do this for a project..
Old Sep 11, 2007 | 03:51 PM
  #53
Andres_Miami's Avatar
Andres_Miami
How did you loose the pinion nut? I heard it is pretty hard, unless that you have touching the ground,is that tru?
Old Sep 11, 2007 | 04:16 PM
  #54
bleunetizen
i put a screw driver in one of the bolt holes of the flange to lock it up against the floor.. it came off pretty easily..!
Old Sep 22, 2007 | 07:33 AM
  #55
OH6 G35's Avatar
OH6 G35
Sub...for an informative thread !
Old Oct 21, 2007 | 11:52 PM
  #56
KRRZ350's Avatar
KRRZ350
Nice job, you must love it Like... Alot!
I really thought you were going to have problems there, unfortunatly some of the factory procedures for reassembly are quite complex and require insanely over priced tools to adjust the Side bearing pre-load, Pinion gear height, Pinion bearing preload, Ring gear to pinion backlash, Ring and pinion gear tooth contact pattern. Out of curiosity, how many miles have you put on it so far, and are you still having any noise or clunk issues?
Old Oct 22, 2007 | 02:39 PM
  #57
bleunetizen
hmm probably good 10000km now.
still driving fine, the diff however got less lock now than before. I am wondering if this is because of the diff oil i used had too much friction modifier in it (Motul PA90 or something like that,,) or i already burnt the clutch discs. At the next service I am going to change it to 80% lock and use the same oil again.
Old Oct 22, 2007 | 08:53 PM
  #58
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Hi,
Can you write up the instruction on how to stack up the discs in order to change the locking %? I searched and found out that for 60% locking, I need to stack 2 of the same discs. Then alternate.. thanks~
Jay
Old Dec 12, 2007 | 07:41 PM
  #59
los06z's Avatar
los06z
are these the oem parts needed to complete the FD build?
2 x side oil seal
2 x side bearing
1 x pinion seal
1 x front pinion bearing
1 x rear pinion bearing
1 x pinion gear spacer
as of now i have the pinion nut, crush sleeve and pinion oil seal...can I get away with the install with just that...or do I need to get what's in that list above?
Old Dec 14, 2007 | 02:45 PM
  #60
n1cK!'s Avatar
n1cK!
Infiltrator!
what's the orientation of the two black spacers that are between the diff mounting bolts and subframe?
