Cusco RS and 3.9FD install
Old Dec 1, 2006 | 03:30 PM
Super Avan Z33's Avatar
Super Avan Z33
Can somebody tell me what to get? I bought a used Nismo LSD for my 2004 base model 350z, it does came with 2 stub axles, it that all I need or do I need any other additional parts for the install?
Old Dec 1, 2006 | 04:44 PM
bleunetizen's Avatar
bleunetizen
you will need at least two oil seals for the stub axles.. change them no matter what, its not worth trying to save few bucks by risking the diff to spray out the oil all over your rear end
I assume the lsd came with the bearing fitted already.. but I would get new side bearing just to feel safe and for the sake of 'noiseless' operation!
Old Dec 1, 2006 | 07:53 PM
Super Avan Z33
Thanks for the great infor, do I need 1 or 2 side bearing? is it have to be the Nismo one or just the normal one?
Old Dec 1, 2006 | 10:10 PM
bleunetizen
replace both side bearings, get genuine nissan bearings, they're not overly expensive
Old Dec 2, 2006 | 12:09 PM
Super Avan Z33
are they available at the Nissan dealership?
Old Dec 3, 2006 | 12:42 AM
bleunetizen
yes!
Old Dec 3, 2006 | 07:18 AM
Kolia's Avatar
Kolia
Originally Posted by 97supratt
When it comes to me and diffs, i'll never assemble or disassemble one, too sensative for me. lol
+1
I'm not equiped to balance a "hot rotating bit" myself.
By the way bleunetizen, did I miss the part where you chim and balance the diff in the housing so it doesn't twist and torque sideways ?
Old Dec 3, 2006 | 10:36 AM
bleunetizen
i just re-used stock shims on both lsd and pinion gear, and luckly they aligned perfectly
Old Dec 3, 2006 | 03:21 PM
Kolia's Avatar
Kolia
Very lucky indeed.
These shims are sold in .05mm (that's .002in) increments...
What were the odds of a .05mm match I wonder?
Old Dec 6, 2006 | 02:32 AM
bleunetizen
yeah but i don't think it actually needs to be that accurate because there is quiet a bit of allowance it gives. I did not use a spring gauge but it was pretty much equally tight as they were stock.
been driving it for about 500km now, the fd makes zero noise. I do however get a tiny bit of noise from the lsd when applying gas or heavy engine braking with the steering wheel is locked on both sides, nothing that bothers me really. during normal driving or thrashing around corners, the diff was totally silent, just like stock.
it was so much easier to control the car sideways now. i was doing figure 8's in low speed lock to lock, then i started applying a bit more gas gradually, and i was very confident in doing figure8's in sideways lol. its so predictable and controllable. i should do some more figure 8's time to time without sliding the car and probably will get the oil changed during this weekend.
i have zero complaints so far. its quiet, easy to control, better traction, better confidence, etc etc. cant recommend it more
Old Dec 6, 2006 | 07:30 AM
97supratt's Avatar
97supratt
Thats a great mod man. So what other performance mods do you have?
Old Dec 6, 2006 | 10:05 AM
bleunetizen
Below are my mods..
- AAM Intake Plenum spacer
- Thermal Intake Gasket
- Simota Panel Type Sports Air Filter
- Stainless Headers
- Stainless Y pipe
- Fujitsubo Regalis Cat back stainless exhaust -3 inch inlet
- UR Lightweight Crank Pulley
- NGK Iridium Spark Plugs
- Engine Torque Damper
Suspension
- BC Fully adjustable Coilovers suspension kit, 10Kg/mm front, 8kg/mm rear
- Cusco Stablizer bars - front and rear
- Superpro Poly urethane swaybar mount bushes - front and rear
- SPC Camber and Toe kits
Drivetrain
- Cusco Type RS LSD
- 3.9 Final Drive Gear
Brake
- Brembo calipers
- DBA4000 Slotted Rotors front
- Ferodo DS2500 Brake Pads front
Old Dec 6, 2006 | 10:59 AM
97supratt's Avatar
97supratt
Below are my mods..
- Stainless Headers
- Stainless Y pipe
Suspension
Drivetrain
- Cusco Type RS LSD
Brake
- Brembo calipers
A lightweight clutch and flywheel setup will also help with your combination.
Old Dec 6, 2006 | 12:01 PM
bleunetizen
yes, but my stock clutch is holding the power nicely at the moment, I will probably go for oem clutch with lighter flywheel when the clutch goes..
and my only power mods in the future probably will be cam/ecu, those results that tomei puts up for their drop in cams look pretty good to me. and maybe some kind of temperature sensing method to see if i am in danger zone..
Old Dec 6, 2006 | 12:06 PM
97supratt's Avatar
97supratt
+1 on the flywheel but why not the clutch? I understand the clamping force on some of the clutches are high, but the clutch disc is also important. Plus if you go with Tilton, you can get a pretty lightweight setup.
Cams and ECU will do wonders with your mods, it'll really open things up.
Old Dec 6, 2006 | 04:06 PM
bleunetizen
because i don't think aftermarket clutches are needed unless stock clutch cant handle the power
Old Dec 11, 2006 | 02:34 AM
bleunetizen
I drove it for about 500~600km, did some figure 8's and full lock turns time to time. the lsd started to give me this grinding noise when doing full lock turns. that didnt happen when i first drove it around after the install, the noise actually got worse over time. the noise however, completely went away when the diff got hot.
so I decided to do my first oil change, guessing there should be fair amount of crap mixed up in the oil due to the lsd/fd gears being new.
drained the oil and W T F ! I havent seen such a wasted oil before! the oil turned into metallic darkgrey/purple colour. there were fine metallic dust floating around too
put the new oil in and went for a run to see if it was making any difference. the noise is gone again, the lsd became smoother overall. i guess the noise was occuring from the oil containing too much of crap in it. be interested to see how long it will last before it does that again.. I will be chaning the oil after 5000km..
Old Dec 16, 2006 | 03:22 AM
  #38
bleunetizen
after the oil change, i measured the 80-120km accel again and it gave me 3.29~3.32sec constant. so thats down by 0.27sec from the fd upgrade, I am happy with it
Old Dec 17, 2006 | 12:50 PM
  #39
240sx2jz's Avatar
240sx2jz
hey do you guys know how many splines are on the stubshafts?
Old Dec 17, 2006 | 01:36 PM
  #40
MI 35th's Avatar
MI 35th
OGPremierMafia
great writeup!
