DIY - clutch install
Old Dec 10, 2011 | 07:51 AM
ian99rt's Avatar
ian99rt
Originally Posted by QuicksilverZ33
Sorry for bumping an old thread but how high must the car be lifted to clear the transmission completely being removed from underneith the car?
I was able to do it on regular harbor freight jackstands. I did not fully remove the transmission from beneath the car though.
Just dropped it on the ground and back way up so I could change the damn csc on my 07
Old Dec 30, 2012 | 08:20 AM
datboyvinh's Avatar
datboyvinh
So my friend a while back followed this 90ft lb then 93ft lb when torquing the fly bolts and broke the bolt in crank.
Went back to the service manual and found out its only 62-68 ft lb!
Old Dec 30, 2012 | 03:07 PM
datboyvinh's Avatar
datboyvinh
http://www.jimwolftechnology.com/wol...GEN-2-ONLY.pdf
JWT has the fly bolts torqued at 70-75 ft-lb
Old Dec 31, 2012 | 12:30 PM
binder's Avatar
binder
That's because the 93 number he is using on the service manual is Newtons not ft lbs. It says the ft lbs in parenthesis. Always helps to read the key at the bottom of any schematic.
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
