Clicking Noise from Rear Axle,
Old Jul 18, 2015 | 08:52 AM
  #181
rich2342's Avatar
rich2342
I have now gone through two replacements of bearings and now, it seems like I may need another. My problem seems that the axle nut is backing off leading to pre-mature wear. The nut was replaced prior and torqued to spec I would assume.
Whats to prevent the nut from backing off? I just re-snugged it with about 150lb/ft. likely have to get it replaced still since the bearing is probably damaged.
Old Jul 18, 2015 | 10:52 AM
  #182
F2CMaDMaXX's Avatar
F2CMaDMaXX
The clicking noise is due to the grease and warmer weather, it's normal, the grease is to pack it out and silence the movement. However, your nut shouldn't be backing off, sounds like you might not be doing all it says in the shop manual?
Old Jul 19, 2015 | 09:51 AM
  #183
Italianjoe1's Avatar
Italianjoe1
There's no reason a new nut that's properly installed and torqued is gonna back itself off. Who put it on?
Old Jul 19, 2015 | 10:20 AM
  #184
OldManZ350's Avatar
OldManZ350
Look for grease splatter around the DriveShaft at the front and rear U-Joints. If you see ANY! DriveShaft is done and you need a new one. It is not rebuildable. I got an aluminum racing drvieshaft from DriveShaftspecialist.com
Old Jul 19, 2015 | 02:46 PM
  #185
rich2342's Avatar
rich2342
My car sits from summer to summer in the northeast conditions. Was frequently buried under snow.
When I first noticed the car was unstable in the rear (again) it was april 2014 and I brought it to a guy who has worked on it before. He snugged up the axle nut while I was there watching and the slight wiggle from the wheel was alleviated, however the tracking/wiggle wasn't after that.
Fast forward to this season the car has been sitting with mis-matched tires which I thought was the issue. Just had brand new Extreme performance summers put on and noticed the wiggle still there. Jacked up car checked wheel and there was articulation if you push on the top of the tire toward wheel well. The bearing was either going and the nut backed off somehow.
I doubt the tire tech backed it off, but who knows. If not a rusty axle could be the issue.
Just dropped it to another guy to replace this bearing. Hopefully it solves the issue.
Old Jul 19, 2015 | 04:45 PM
  #186
superlim9's Avatar
superlim9
Are they installing the cotter pin correctly?... not sure how it can be done wrong... but also make sure its the right size pin
Old Sep 19, 2015 | 10:45 AM
  #187
i-break-things's Avatar
i-break-things
I thought the Axle nut tq was 208 ft lbs?
Old May 21, 2016 | 08:30 PM
  #188
AnthonyJ350's Avatar
AnthonyJ350
Here's our version of the click fix. Re-tightening the large nut on the axle shaft probably has a lot to do with it.
Old Jun 29, 2016 | 05:16 AM
  #189
Heritage's Avatar
Heritage
^wouldn't that make it a whoring raging biatch to get out if you ever have to replace your axles?
Old Jun 29, 2016 | 04:10 PM
  #190
Italianjoe1
Na a little hammer action will remove that axle with no problems.
If done properly with grease or anti-seize it will also last the life of the bearing though, lock-tite seems unnecessary in this application to me. As they mention, cleaning is the most important step and people seem to skip that. I removed my axle to clean and grease it, if you just push it back and squirt a little grease in there you are just covering up the rust with it, not right.
Old Jun 29, 2016 | 05:10 PM
  #191
rich2342's Avatar
rich2342
How does the locktite adhere after the splines were greased?
Old Jul 2, 2016 | 12:10 PM
  #192
Italianjoe1
It doesn't?
They show cleaning everything down with brake cleaner, then putting loctite. No grease.
Old Sep 20, 2016 | 07:40 PM
  #193
nizmo_0385's Avatar
nizmo_0385
does this tsb cover 07-08? having this issue
Old Sep 22, 2016 | 03:05 PM
  #194
Italianjoe1
Happens to all of them. Open it up and clean it, apply grease.
Old Sep 22, 2016 | 03:17 PM
  #195
Freise's Avatar
Freise
Since this was bumped I just wanted to add my anecdote of just tapping the splines out the of the hub with a mallet, greased and reinstalled. Took about 25 minutes and got rid of the click, no need to remove axle at the diff.
Old Sep 27, 2016 | 09:15 AM
  #196
kamz's Avatar
kamz
Ok so doing this today and I totally forgot to mark before removing. Did I just **** up royally? Any harm in not having marked so I'm basically putting it back together blindly at this point.
Old Oct 3, 2016 | 03:27 PM
  #197
Italianjoe1
No it will still be ok. You could possibly get a vibration after it's back together but that's unlikely.
Old Mar 19, 2018 | 02:41 PM
  #198
LATEZ's Avatar
LATEZ
after 14 years with this Veh I developed this clicking noise...greateful this write up is still here
ben
Obadabot
Jun 18, 2023 11:31 PM
