DIY - Transgo Valve Body Upgrade
Old Feb 7, 2011 | 09:54 PM
  #61
Adrians07Z's Avatar
Adrians07Z
Looks about like mine
love the barking tires through all the gears
as for the power the stock tranny can handle .. im not sure, but ive seen 450hp somewhere WITH the shift kit .. im assuming thats with an aftermarket / bigger cooler .. but dont quote me on this
Old Feb 24, 2011 | 11:04 AM
  #62
MardiGrasMax's Avatar
MardiGrasMax
How is the 3 to 4 shift for you guys with the transgo kits and boost? Does it slip for a split second then engage or is it solid hard shifting like the lower gears? If you leave the trans in DRIVE will it hit the rev limiter or does it shift fast enough?
I ask becuause I am considering the Transgo kit to replace my VB which was modified by SGP before the trans go kits were out. I works great in manual mode 1-2, 2-3, but I slight slip in 3-4 which cost me several tenths. And in DRIVE I hit the rev limiter in every gear and it wont shift.
Look at this video and pay attention to my 3-4 shift.
http://www.youtube.com/embed/KQOEejGkf0o
Old Mar 8, 2011 | 07:45 PM
  #63
tcho's Avatar
tcho
I'm really interested in getting this kit. Currently, I'm hearing grinding noises 1-2 with wot. It's driving me nuts. Does the TG kit fix this problem? I have no knowledge in Trans...... TT
Old Mar 8, 2011 | 08:06 PM
  #64
SexyRob's Avatar
SexyRob
transgo instructions state that your tranny must be in good working condition before attempting this upgrade. it may make problems worse if you install it.
Old May 19, 2011 | 05:51 PM
  #65
will-z's Avatar
will-z
Originally Posted by aloh
though it looks pretty involving, Im pretty sure I could ahve done it myself now that i have seen this. Too late now since I already had a shop do it... Ohhhh well
But this is definitely an excellent upgrade! Man...I really want to take it apart and check my VB though. My 4-5 shift is very sluggish... All the others are lightning quick.
Hey, how did you solved the 4-5 sluggish shift from 4-5? I am experiencing the same issue.
Old May 19, 2011 | 09:45 PM
  #66
tollboothwilley's Avatar
tollboothwilley
i think the 4-5 shift was designed to be similar to stock - not used in racing like the rest of the shifts.
Old May 20, 2011 | 05:36 AM
  #67
bottlefedZ's Avatar
bottlefedZ
Yes shifts 4-5 remain untouched with the Transgo kit.
Old May 20, 2011 | 06:01 AM
  #68
gordenZ's Avatar
gordenZ
Rather interested in this.
How well does the transgo vb upgrade work with a reflash?
Thinking of possibly doing Transgo / Shift Paddles upgrade after full bolt-ons...
Does anyone here currently have this upgrade with a flash?
Old May 22, 2011 | 08:15 PM
  #69
tollboothwilley
i've heard that with the Transgo + Osiris torque management you have even more crisp shifts all around. Someone on g35driver was talking about it since they had both.
Paddle shifters would be nice!
Old Aug 9, 2011 | 10:13 AM
  #70
cabos g35 coupe's Avatar
cabos g35 coupe
anyone in northeast area know a shop or know how to install my transgo kit im from MA
Old Aug 9, 2011 | 12:06 PM
  #71
350Zdj's Avatar
350Zdj
Superb writeup OP!
I just received mine a week ago but havent installed it yet.
Guys any idea what's the purpose of drilling those holes?
Old Aug 9, 2011 | 09:53 PM
  #72
Adrians07Z's Avatar
Adrians07Z
Originally Posted by 350Zdj
Superb writeup OP!
I'm not a transmission expert .. but I'm assuming its to allow the flow of more fluid through the valve body
just hit 53k miles and still shifting just as hard as it did when I installed the kit .. think I'm a lil over due for a tranny fluid change, so thats next on the to-do list
bought a bike a few months ago .. so the Z has been resting a lil .. haha
Old Dec 30, 2011 | 11:25 AM
  #73
blAk mAx's Avatar
blAk mAx
is the kit just a set of bolts and springs?
Old Mar 16, 2012 | 06:21 AM
  #74
phreaktor's Avatar
phreaktor
Design Engineer
Between this and 3.5 gear, it sounds like it would make the car so much more fun to drive
Old Jul 5, 2012 | 03:14 AM
  #75
romeov's Avatar
romeov
Default Normal driving?
How does this handle under normal, non power driving? Does the trans still shift smooth and calm or do the tires chirp when you're just going to get groceries in town? at 35MPH
Old Jul 5, 2012 | 05:20 AM
  #76
SexyRob's Avatar
SexyRob
under light load you hardly notice its there.
Old Jul 5, 2012 | 06:59 AM
  #77
blAk mAx's Avatar
blAk mAx
Under light loud mine seems like it doesn't want to shift and seems to slip a bit. It's to the point where I don't use it now. I had it installed while getting a turbo kit installed. I also have a heavy duty tranny cooler.
Old Jul 5, 2012 | 07:46 AM
  #78
SexyRob's Avatar
SexyRob
thats probably because they upped the line pressure when tuning so it would hold the power of your turbo.. thats what happened to me. but I remember when I was NA it was pretty chill under light load.
Old Jul 3, 2020 | 10:35 AM
  #79
Miguel A Durand's Avatar
Miguel A Durand
Adrian do you have those pdf sheets?
Old Jul 3, 2020 | 02:56 PM
  #80
jhc's Avatar
jhc
General & Tech Moderator
Hasn't logged in since Aug '11.
