DIY Headers, also HR manifolds on a DE
Old Jul 17, 2010 | 07:51 AM
12AutoX's Avatar
12AutoX
Default DIY Headers, also HR manifolds on a DE
Here's the link. I didn't feel like copying the whole thing over to this site.
This is proof that HR manifolds or headers will work on a DE motor. You just have to mount the manifold studs on the center pipes in their alternate locations. If you decide to do this for whatever reason, you will need HR test pipes or cats.
http://members.***.net/lawson370/350z_005.htm
Old Jul 19, 2010 | 11:55 AM
aggietsi's Avatar
aggietsi
Too bad he doesn't get any dyno proof.
Old Jul 22, 2010 | 12:25 PM
sir_vq's Avatar
sir_vq
Originally Posted by 12autox
here's the link. I didn't feel like copying the whole thing over to this site.
This is proof that hr manifolds or headers will work on a de motor. You just have to mount the manifold studs on the center pipes in their alternate locations. If you decide to do this for whatever reason, you will need hr test pipes or cats.
nice write up but did you feel any gains at all, do you think it would pay to do with hr headers or aftermarket, i just like the fact there is a oem upgrade(if its even a upgrade)
Old Aug 6, 2010 | 05:31 PM
bikinilust's Avatar
bikinilust
nice to hear there is an oem header upgrade.
Just want to see what gains are to be had with this swap: DE headers vs HR headers and HR headers vs aftermarket headers
Old Aug 8, 2010 | 11:04 AM
12AutoX's Avatar
12AutoX
I was hoping to see some dyno results myself, but I ran into some snags. I should have added an aftermarket Y pipe before doing the swap. Then I could have gotten before and after dynos that are meaningful. As it is I ordered the Y pipe after swapping the headers because I saw how it was choking my system. To make things worse, I am getting some cams installed, and my fu#%ing Y pipe is still backordered! I will have to wait to get the $%^#$%&%* Y pipe before I can even tune the car for cams now.
All I know is this- without a 2.5" inlet Y pipe, there is no point in getting headers. By the time I have the Y pipe, I will have installed so much stuff that any meaningful dyno comparison to the car before doing the headers will be worthless. Motordyne is working on the Y pipes, but they are hopelessly behind schedule.
I didn't feel any gain or see any increased airflow from my W/B, mainly because of the whole Y pipe thing. Increasing the size of the header outlet has no effect if the exhaust is still corked up.
Old Aug 8, 2010 | 09:34 PM
bikinilust's Avatar
bikinilust
thought of an idea that'll make the swap cheaper...
*remove your DE headers
*cut off the "header to cat flanges" off the DE headers
*cut off the "header to cat flanges" off the HR headers
*make sure DE flanges fit snugly on HR headers [fitment test]
*bolt DE flanges to your DE cats w/gaskets installed
*install HR headers
*install exhaust and cats
*weld the bolted DE flanges to the HR headers
and now you have converted your HR headers to work with your DE exhaust and cats
Old Aug 11, 2010 | 10:03 AM
shiftdrift06's Avatar
shiftdrift06
So i am assuming it bolts on to stock (DE) y-pipe/exhaust system if you use the HR Testpipe/Cats as well?
Old Aug 11, 2010 | 10:08 AM
Nexx's Avatar
Nexx
here is the thing. the header install on a Z is such a pain in the ***, i would make sure the effort is worth it. in that case im gonna at the very least buy a set of used headers that are proven.
Old Aug 11, 2010 | 12:09 PM
SniperHunter's Avatar
SniperHunter
If you can get a set of HR headers for dirt cheap (less than $100), in total everything should run about $300-400 after install. If the install price is right, the power to cost ratio should be justifiable, I'd say.
Old Oct 9, 2011 | 02:01 PM
350z-Na's Avatar
350z-Na
i know it's an old thread but just to make sure. The holes for the studs are pre-drilled from factory? All i have to do is to switch the studs and i can install it right?
Old Aug 27, 2013 | 01:06 AM
mw9's Avatar
mw9
anyone?
