DIY Wire Tuck
Old Oct 13, 2010 | 09:07 AM
Heist.'s Avatar
Heist.
Post DIY Wire Tuck
Posted this over on G35driver, but I know a lot of Z owners like to get busy in the engine bay. Hope this helps some enthusiasts!
LINK:
Wire Tuck DIY
Old Oct 13, 2010 | 09:16 AM
JasonZ-YA's Avatar
JasonZ-YA
wow....thats some patience right there....
could you post sequential pics in this thread copy pasting the directions incase the site ever goes down please???
-J
Old Oct 13, 2010 | 09:22 AM
350Z_Al's Avatar
350Z_Al
On the TO-DO list that goes
Old Oct 13, 2010 | 12:24 PM
10-E-C-350Z's Avatar
10-E-C-350Z
Holy crap that's clean.
Old Oct 13, 2010 | 02:01 PM
831_Z33's Avatar
831_Z33
Wow i didnt now a wire tuck could be done on a Z/G Very impressive. Well done!
Old Oct 13, 2010 | 08:41 PM
Heist.'s Avatar
Heist.
I would post directly to the site, but its all in HTML. The site should stay up its gaining ground . Its a big project, but I hope this helps for anyone who takes it on!
Old Oct 13, 2010 | 10:02 PM
10-E-C-350Z
How long did it take?
Old Oct 14, 2010 | 08:29 AM
Heist.'s Avatar
Heist.
I did it in one day. From dawn till dusk. When I started I really had no clue what I was doing though... so now probably would only take me 4-6 hours.
Old Oct 14, 2010 | 10:11 AM
350Z_Al's Avatar
350Z_Al
I'm going to start mine in a few minutes
Old Oct 14, 2010 | 10:24 AM
831_Z33's Avatar
831_Z33
Pics please ^^^^^
Old Oct 14, 2010 | 11:36 AM
350Z_Al's Avatar
350Z_Al
Originally Posted by 831_Z33
Pics please ^^^^^
I'm taking lots...
Plenum and all misc crap is off. Just about to cut into the loom.
Old Oct 14, 2010 | 12:02 PM
350Z_Al's Avatar
350Z_Al
Harness is stripped
3:13pm Edit: DR Side wiring is sorted out, ready to be re-run after I modify the pass side wire bracket.
4:00pm Edit: Done and cleaned up for tonight. I need to do some studying
Last Edit: Heist, Going through your pics you did the body harness on both sides of the shock towers as well... Very Nice! Do you have any pics of how you did those two harnesses? I would think wires will need to be extended...
Old Oct 14, 2010 | 12:10 PM
zaperroni's Avatar
zaperroni
^ picss
Old Oct 14, 2010 | 01:52 PM
350Z_Al's Avatar
350Z_Al
A little something something I spent a couple free hours on today. Car needs to run on Sunday because I need the garage for another project, so Sunday is the deadline for getting this one done.
Right now I'm just doing the engine harness. I'd love to do the two body harnesses under the hood as well, we'll see.. Maybe later this winter when I pull the front end apart to install other misc stuff.
Before:
Starting to strip the intakes off:
Starting to strip the harness:
Sorting out the wiring:
Modified the wire harness cover on the passenger side. Shortened it about 6" to allow the harness to go to the drivers side instead of the passenger side. Cleaned up and ran as little wire as possible on the passenger side. Coil packs, Cam timing wiring and a couple other misc wires all run down by the coil packs. They should hide real well once the intake manifold is on.
The rest of the wires will get run down behind the motor, above the transmission instead of being on the front of the motor. The wires for the driver's side front of the motor (Cam timing, MAF and A/C) will be run under the intake piping.
That's all for today. Time to study.
Old Oct 14, 2010 | 04:11 PM
bbs350z's Avatar
bbs350z
lookin good. id be careful with some of the wiring as it has rf(?) shielding and is super sensitive to cutting. i tucked mine but just by using self wrapping braided nylon, instead of the ugly clumsy stock looming.
keep us updated on the pics!
Old Oct 14, 2010 | 05:01 PM
350Z_Al's Avatar
350Z_Al
I'm not actually cutting or shortening anything. I plan just to double over some of the wiring that is too long.
Thanks for your pic.. If I didn't have a time limit to do this, I should have pulled my valve covers and painted them
Old Oct 14, 2010 | 08:51 PM
Heist.'s Avatar
Heist.
For the battery and headlight harnesses I didn't have to cut or extend any wires. I will be posting a DIY for that soon.
Old Oct 15, 2010 | 05:14 AM
350Z_Al's Avatar
350Z_Al
Sweet! Thanks a lot for the inspiration!
Old Oct 15, 2010 | 10:47 AM
IntenseSales's Avatar
IntenseSales
Vendor - Former Vendor
NICE DIY thread... great pics.
We've done this on numerous cars along with shaving the bay and it is very time consuming.
Props for tackling this on your own.
Old Oct 15, 2010 | 08:08 PM
350Z_Al's Avatar
350Z_Al
* Sorry for the crappy pics today.... No sunlight and a cell phone camera *
Ok, now on to today's progress:
I finally got annoyed and just took the damn hood off. Soooooo much easier to work now!
This is what I started with tonight:
First up was the main bulk of the harness. This one is nice to work with, all the wires are the same length and there are no connectors or anything in it. I had some extra slack do deal with:
I ran ALL the wires going to the drivers side under the fuel hard line just to get them a bit lower down to hide them better. The mess that you see in this pic is all the wires for the passenger side coil packs. These wires SUCK! They are all different lengths with misc butt connectors and crap in them:
Most of the wires were nice and even length to their respected connectors. With those I worked from the main harness out towards the connector. Because the Coil Pack wires were all whack I actually cleaned and did the wiring at the coil packs first, then worked towards the main harness. This is the finished passenger side coil packs:
Getting closer to the end. I still have the Throttle Body, Pass Side Cam Timing, A ground for the coil packs and the MAF sensor left:
This is what is left for tomorrow. I had to extend a few grounds for the coil packs. I`m going to hide the ring terminal under the cam phase sensor/actuator. I also had to extend the two wires for the cam phase sensor/actuator so I could run them low enough to be hidden:
I don`t have any of the right size wire loom, so the wires are just taped up for now. The car is being stored for the winter right now, so I`ll loom everything up when the intakes come off again to do the fuel system and fuel injectors.
There was an ungodly amount of brackets holding the motor cover and wire harness on the motor. These all aren't needed anymore. Getting rid of these cleans up the front of the motor a lot. I still have to pull of the two studs from the engine cover.
These are just a few of the brackets that came off:
So far I have about 4 hours into it. 2.5 hrs yesterday and 1.5 today. Today wasn't too productive though, I had a couple girls that wouldn't leave me alone
