Stillen short-throw DIY and pics!
Old Aug 31, 2010 | 12:54 PM
350ztttt's Avatar
350ztttt
Default Stillen short-throw DIY and pics!
Hey, not a lot of people seemed to be getting these, so I decided to check it out. Here's a walkthrough of the install, it was a total breeze, and the throw is insanely short!!
First, you need to take a screwdriver and pop up the center console just like you would if you would be putting in a shift boot.
Next, use the screwdriver to undo all the clasps that hold the wiring to the temperature and hazard light controls
This next part is a little tricky. The four corners of this rubber boot are bolted down with 10mm bolts, but the lower passenger side one is a PITA to get in and out. When re-installing everything, I strongly recommend not even bothering to put this one back in. Trust me...
Once that is up, remove the boot and the square metal tray. You now have left the triangle thingy, which holds down the whole shifter-apparatus and keeps it connected to the transmission. Undo all this crap. (This picture was taken during reassembly, because the next steps are under the car, and I didn't want to mess up my new Sony ax200)
Now to take the shifter out all the way, you need to put the car up on jacks. There is a rubber boot covering the bottom of the shaft, take this off to access the pin. Undo the pin, and put the new shifter in.
Now to make the new shifter function properly, you actually have to shave the inside of the square hole in the gearbox! Take a metal file and shave the upper left corner of the box about 1/2". YOU WILL LOSE THE FUNCTION OF PUSHING DOWN ON THE SHIFTER TO GO INTO REVERSE. YOU NOW JUST THROW IT ALL THE WAY TO THE RIGHT AS YOU WOULD IN AN M3! Weird to get used to, horrifying and irreversible to shave your gearbox, but worth it for the quickshifter!
Anyways, Install the blue plate with the thicker side on the left, as seen below, and install all other parts!
I drove around like this for a while for fun, but got really lightheaded after 15 minutes...
And finished!!! Hope this helps anyone considering this.
Old Aug 31, 2010 | 01:03 PM
hellsoldiers08's Avatar
hellsoldiers08
im pretty sure that you dont need a screw driver to take off the plastic around the shifter.
Old Aug 31, 2010 | 01:09 PM
350ztttt's Avatar
350ztttt
ok.
Old Aug 31, 2010 | 01:50 PM
sdZ33's Avatar
sdZ33
Yup, just dig your hand into the leather boot and pull it up...
Would it have been easier to take out the center console?
Old Aug 31, 2010 | 02:50 PM
350ztttt's Avatar
350ztttt
^^thanks for the tip, didn't even occur to me. What do you mean about removing the center console. I was pretty sure that's what I did.
Old Sep 20, 2010 | 10:08 PM
hellsoldiers08
well in the nismo short shifter, that i helped install in my brothers Z. They said to do that what Sd said. Im guessing your instructions didnt say that :/
Old Sep 22, 2010 | 04:07 AM
derekinthez's Avatar
derekinthez
I'll have to get one of these as soon as my build is done.
Old Apr 22, 2012 | 08:29 PM
Noor93y's Avatar
Noor93y
So changing the shifter changes where reverse is??? Never knew that. so it becomes
R 1 3 5
..2 5 6
Old Apr 22, 2012 | 09:56 PM
Emski's Avatar
Emski
He said throw it to the RIGHT.
Old Nov 28, 2012 | 07:36 PM
efefef's Avatar
efefef
Would it still work if I do not file that hole in the gear box?
Just don't want to stuff something expensive up.
Old Nov 29, 2012 | 07:46 AM
myork's Avatar
myork
I would use the instructions included with the Stillen shifter as they are spot on correct, with no mention of filing anything off the transmission.
http://www.stillen.com/product_files/452350~inst.pdf
Old Dec 3, 2012 | 08:52 PM
efefef's Avatar
efefef
I would do a update on this after my installation.
Should be bolt on
350Z_Al
Oct 29, 2020 07:44 PM
Fixxxercask
Nov 9, 2015 11:10 AM
Tochigi_236
Sep 27, 2015 03:40 PM
